2jz swap questions
I’m doing a 2jz swap to my rx8 so far I figured out the drive shaft and custom mounts. Now I need help with the wiring I did research and I have to use both ecus. I now some of the pins where I need to tap but do I run wires to one ecu to the other? (Rx8 to 2jz?) or (2jz to rx8?) wires I need to tap from the 2jz ignition 1,2,3 ecu power and ground and injectors are my main concern. One more thing rx8 has 4 injector and 2jz 6. I want to try some 550cc injectors form a 350z but I’m kind of new with the whole high resistance can someone explain?? I don’t think I need a resister box for that right?
