IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Ocv
Old Jul 24, 2013 | 04:47 AM
gotyme's Avatar
gotyme
Default Ocv
Daughters 2001 IS 300
Has 277,000 miles, shop diagnosed oil control replace as cure for catastrophic misfire thus putting the car into safe mode.
estimate was to replace timing belt, water pump, OCV $1200
Would replacing the OCV only correct the issue? and what is cost to replace OCV?
thanks
gotyme
Old Jul 29, 2013 | 05:26 AM
ToyotaPro's Avatar
ToyotaPro
thanks
gotyme
I cant tell exactly but at Toyota they are usually $150 range and could be installed yourself most of the time. The problem with an OCV failure with mileage that high is a good chance that there is engine sludge causing some VVT-I issues with oil flow. If it continually has issues related to VVT-I and it does exhibit engine sludge it would need a new engine more than likely.
KyleH
Mar 25, 2016 08:30 PM
mikefly
Sep 17, 2012 08:53 PM
VIP161
Performance
13
Feb 14, 2012 04:27 PM
Papajorgio
Aug 1, 2009 05:22 PM
GOLDSc300
Jan 28, 2009 07:32 AM
