IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Now what?!?!?!?!??!?!?!?!?!?!?!?!?!?!?!?!?!?!?
Old Jun 19, 2012 | 05:54 PM
cubbieblu7's Avatar
cubbieblu7
Exclamation Now what?!?!?!?!??!?!?!?!?!?!?!?!?!?!?!?!?!?!?
So im doing an oil change buh i first looked at a youtube video to see where the oil drain plug was. Buh my stupid *** took off the trans one maybe a 1 1/2 quart drained out before i put the plug back. So my question is should i juss completely drain it out and put new or wat? Also wat kind of trans oil should i use to fill it bak up or to put new one. My is300 has 86000 miles.. Sorry for the languange buh true. Thanx for the help
Old Jun 19, 2012 | 05:57 PM
Endika's Avatar
Endika
i would just drain the trans and put in new oem trans fluid
Old Jun 19, 2012 | 06:05 PM
Kyoei's Avatar
Kyoei
Relax, no need to panic. Just buy some Toyota T-IV transmission fluid (can buy it at the dealer) and pour in 1.5 qts (or however much drained out) through the transmission fluid dipstick. So essentially what you do is a transmission fluid drain and fill. This is good to do every 30K miles or so.
Old Jun 19, 2012 | 06:38 PM
cubbieblu7's Avatar
cubbieblu7
Oh ok yea for a sec i did. I was told diff. I was told dat i cant drain it out cause of high mileage (which i thought i have good miles for my 01) cause it got used to the old one it had and ur not suppose to change trans oil juss engine oil. (btw the guy at oreilly said dat).
Buh thanx ill do dat.
Old Jun 19, 2012 | 06:47 PM
Kyoei's Avatar
Kyoei
I wouldn't flush the fluid out, maybe that is what he meant. But drain and fill is safe. As you saw, it only drains about 2 qts, so to get all new fluid in there you will have to do more drain and fills until the fluid is mostly new. For now, maybe do a couple more every oil change or every other oil change. Your fluid is supposed to be cherry red, so you'll know when you've done enough drain and fills.
Old Jun 19, 2012 | 09:12 PM
cubbieblu7's Avatar
cubbieblu7
Yea well i finished now. Hope it lasts if not looks like ima get a new trans.
Buh thanx for the help.
LocalIS300
Jun 29, 2015 03:36 PM
ajay60610
Oct 26, 2014 07:43 AM
schmoozer
Jan 11, 2014 01:07 PM
Hollywoood
Mar 17, 2013 08:24 PM
OutlawTita
Maintenance
Apr 16, 2010 01:38 PM
