IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Help me find these gaskets please
Old Aug 10, 2011 | 01:44 PM
jarred1580's Avatar
jarred1580
Default Help me find these gaskets please
I don't know what these gaskets names are. I can't seem to find them? If you know the name i can use to find them, website, or part number that would be great.
Old Aug 10, 2011 | 02:53 PM
Justin727's Avatar
Justin727
Toyota can get those 2 gaskets. But why are you replacing the 1 behind TB?? Is it cracked/ripped? Part # 22271-46070
I've always told Toyota that other gasket is the top of the intake manifold gasket aka Y pipe gasket. Part #17849-46020
Old Aug 16, 2011 | 09:29 AM
jarred1580's Avatar
jarred1580
Im doing plugs, wires, and valve cover gaskets. So while i have the throttle body and y pipe off i figure i might as well replace those gaskets. I'd rather have them on hand anyways even if i wasn't planning on changing them in case they ripped while doing this job.
I had got the part numbers already thank you. parts.com had the gaskets muchhh cheaper then dealership. and still genuine oem parts.
Old Aug 16, 2011 | 09:48 AM
Justin727's Avatar
Justin727
I understand the y pipe which meets the plenum gasket. But that solid gasket behind the TB I've never had to replace as it's a pretty strong gasket unless you're wrenching down pretty hard on it.
Old Aug 19, 2011 | 06:07 AM
ais300c's Avatar
ais300c
if your doing plugs wires and gaskets you dont need to disassemble those parts. just remove all lines from intake and move it out of the way I almost did the same thing until i realized I didnt have to lol food for thought just saying
speedkar9
54
Mar 25, 2021 09:28 AM
Oro
Jan 8, 2016 01:22 PM
CF01
Dec 26, 2015 02:03 AM
SClidin300
Sep 10, 2012 06:10 PM
Mr Soarer
Maintenance
Sep 25, 2007 11:16 PM
