IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS300 starter removal difficulty?
Old Mar 17, 2011 | 05:33 PM
tommyt1777's Avatar
tommyt1777
Default IS300 starter removal difficulty?
My IS300 is not starting. The starter clicks but it does not start. The battery has been tested good and fully charged.
I started on the removal and had a really difficult time getting to the bolts. I did a search and found that I will need to remove the engine cradle and tilt the transmission to get to it.
Basically, I live in an apartment complex and I am not supposed to work on my car in the parking lot. Any idea how long this swap will take with a socket set, socket hinge, 2 jackstands, and a jack?
All of my tools are at my parent's garage. I don't even have a torque wrench.
How many of you guys have actually attempted this with regular handtools and sitting on jackstands? How long did it take?
I don't want to get started and 2 hours in I get fined for working on my car in the parking lot while still having hours left on the install.
Thanks.
Old Oct 21, 2013 | 10:59 PM
Is300Mai's Avatar
Is300Mai
Thanks.
I know this is an old thread but were you able to figure out how to remove the starter? I just ran into the same issue with the top bolt removal. Any help will be appreciated. Thanks
Old Oct 31, 2013 | 06:58 AM
MIS300's Avatar
MIS300
Is300Mai: The lower bolt can be reached with standard tools, 14mm socket I believe. The top bolt does NOT require you to lower the transmission but lowering it does make it easier. Either way, you just need several feet worth of extensions with a swivel end. I've done this job both ways and would recommend leaving the trans alone as this just adds to the potential of not reinstalling something correctly.
Old Nov 4, 2013 | 08:27 AM
Is300Mai's Avatar
Is300Mai
Thank you MIS300! I've gotten it replaced and you are correct the methods you suggested was what I had to do.
Old Nov 5, 2013 | 10:14 AM
MIS300's Avatar
MIS300
Glad it worked out!
Project300
Sep 8, 2021 06:53 PM
Halon
Sep 21, 2016 07:44 AM
techtalk
Sep 2, 2011 01:12 PM
7Cain
GS - 1st Gen (1993-1997)
Nov 25, 2008 12:37 PM
Sadako
15
Jun 11, 2007 04:41 PM
