IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS300 Engine = Supra Engine
Old Aug 25, 2009 | 10:19 PM
DynamicDTS's Avatar
DynamicDTS
Default IS300 Engine = Supra Engine
True or BS? I'v heard so many controversies, don't know who to believe anymore
Old Aug 25, 2009 | 10:20 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
block, not heads.
Old Aug 25, 2009 | 10:24 PM
DynamicDTS's Avatar
DynamicDTS
so the whole engine needs to be modified?
Old Aug 25, 2009 | 11:38 PM
mex lex's Avatar
mex lex
It shares the NA Supra motor, not to be confused with the TT Supra motor (internal wise). Not to say though, that the NA motor is not stout.
Old Aug 30, 2009 | 11:23 PM
white_is's Avatar
white_is
Most people on stock compression and internals don't go above 8 psi. And you should have a GOOD tune. Around 320rwhp.
With a thicker head gasket (to lower compression) most will push around 14psi, again with a good tune. Somewhere in the range of 450rwhp
You can swap GTE internals (pistons, rods, rings, etc.) and a TT head gasket and it will esentially be a GTE block. Which can hold something like 700hp. BUT you have to be very careful doing this and there is a LOT of debate whether to hone the block or not. The TT internals are the same bore as the GE internals so if you take to much material off it will be out of clearance and BOOM.
The exhaust and intake ports on the head are different from the TT and GE. As well as the cams.
It is essentially a NA Supra motor, but from what I have seen the non-vvti internals can hold WAY more power than the vvti internals. Heads are the same, cams are different from non-vvti to vvti head.
WAY more info on my.is or supraforums or clubna-t
Old Sep 7, 2009 | 06:11 AM
IS_almrlon's Avatar
IS_almrlon
Im new to the Forum,
I have a 2002 IS300 which im looking foward to build little by little, however, it will be my daily driver so I'm not looking for a monster but at the same time wanna feel the boost...I'm talking about 300 to 350 horses...MY PLANS ARE TO TURBO THE 2JZGE (((ANY SUGGESTIONS)))?????
Old Sep 7, 2009 | 12:49 PM
IS3_FTW's Avatar
IS3_FTW
Here you guys go...answers!!!
http://my.is/forums/f114/new-forced-...inside-346858/
Old Sep 7, 2009 | 08:29 PM
madchyers's Avatar
madchyers
www.clubna-t.com
Old Sep 8, 2009 | 12:09 PM
ALtEZZA_88's Avatar
ALtEZZA_88
Originally Posted by madchyers
i personally would not suggest this company, i have heard a lot of bad reviews about this as a "BASE" kit.
without doing modifications, you can run into some major headaches.
ISFFUN
Nov 16, 2011 06:24 PM
OEM Turbo
Performance
Nov 13, 2008 11:22 AM
adidosc
May 29, 2003 06:15 PM
dbiggss
Jul 19, 2002 10:15 AM
Tommy
Performance
Sep 16, 2001 08:42 PM
