IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2002 IS 300: bad CD player?
Old Jun 14, 2007 | 09:45 PM
KevinGS's Avatar
KevinGS
Default 2002 IS 300: bad CD player?
I have a friend who just bought a 2002 IS300, and is not yet able to log in to the CL forums. So, I'm posting for him.
He just bought a 2002 IS 300, but the in-dash 6CD changer won't allow him to insert discs. The error message is 'error3'.
Is this a common problem with this model year?
The dealer he bought it from will cover some or all of the costs to replace the unit...and Lexus wants $600.
For that amount, Tweeter already said they could get him into an aftermarket Pioneer or Kenwood head unit WITH a 6-disc changer in the trunk for about $700.
Should he just go aftermarket at this point, or is the stock Lexus in-dash unit worth replacing for about $600?
Old Jun 15, 2007 | 12:22 AM
Faymester's Avatar
Faymester
error 3 = stacker jammed ... about $4xx is normal, $600 sounds up there ... yea its a common problem, mine has been replaced
Old Jun 15, 2007 | 05:07 AM
KevinGS's Avatar
KevinGS
So if it's common, should he just take this opportunity now to go aftermarket?
How long did you head unit last before you had to replace it because of this malfunction?
Old Jun 15, 2007 | 10:15 AM
Faymester's Avatar
Faymester
the car is an 01, and i just had it replaced iiiiiiiiiin .... february of this year ... so ~6yrs i guess
when i went to look into aftermarket, it was really expecnvice because of the shape of the centre dash; apparently there's a lot of custom work that needs fabricating. $700 is probably just for the unit and basic instal, i took mine to an audio shop and they looked at it, and then the guy who would do the installing came out and had a look too: end result is over a grand to go custom, and the actual head unit wasnt going to be as good. i care about sound quality and i definately wasnt intereseted in paying more for less ... i went to lexus
Old Jun 15, 2007 | 08:12 PM
hoser813's Avatar
hoser813
sorry for the hijack but I tried using the cd player today for the first and when I hit load I hear some clicking but dont get an error message and I cant stick it in
Old Jun 15, 2007 | 08:13 PM
hoser813's Avatar
hoser813
i just found this.... might help ya
http://www.lextasy.com/is300_radio_plate_1282_prd1.htm
Old Jun 15, 2007 | 08:57 PM
KevinGS's Avatar
KevinGS
Hmmmmmmmmm....
Thanks for the input, Faye. I always thought a decent aftermarket headunit would sound better than a stock Lexus unit. Maybe not, huh?
Old Jun 16, 2007 | 09:30 AM
Faymester's Avatar
Faymester
means your head unit is wearing out ...
Old Jun 16, 2007 | 05:46 PM
robe818's Avatar
robe818
Thanks 2 my friend kevin 4 posting 4 me till i could log on and of coarse thanks 2 every1 who replied i just got my 1st lexus 2002 IS300 now the world seems so much brighter!!!!
Old Jun 18, 2007 | 04:18 PM
amy011079's Avatar
amy011079
In my PERSONAL opinion I would suggest eventually going aftermarket. I had 3 players replaced in my IS before going aftermarket. I got tired of not being able to listen to my burnt cd's which was part of the problem. The IS stock unit will play them for a while then says "uh uh". Some have good luck with the player and others don't. If you plan on modding your IS you could start with the cd player. Wouldn't hurt. I've got pics of my player if you're interested.
Old Jun 18, 2007 | 07:32 PM
hoser813's Avatar
hoser813
is just a regular single din aftermarket hu? If so, how did you wire it up?
Old Jun 18, 2007 | 08:48 PM
SDLexus's Avatar
SDLexus
If you don't have NAV go aftermarket.
Old Jun 19, 2007 | 07:15 AM
btorok's Avatar
btorok
The CD changers in the IS are crap. It's one of the only real problems with the car, fortunately. If you go aftermarket, there are some considerations.
1. NAV - If you have NAV, you will need to relocate either the entire stock HU or a single circuit board from it somewhere else in the car. (The NAV relies on a relay in the HU to operate). Or you can buy Fargo's NAV module for $110 (price quoted June '07) shipped to the US. http://fargosys.com/html/sat_nav_bypass_module.html
2. Stock amp and rear speakers - The rear speakers are 2ohm and will sound like absolute crap if you run them directly off the aftermarket HU. So, you will have to leave the amp and speakers, or replace them both. The amp is either behind the glove box or in the passenger side kick panel. If you replace speakers, you will need to make mounting spacers.
3. Wiring harness - The Metra harness seems to be the only one that really works. EDIT: The Metra harness doesn't work on the '01.
4. Dash kit - If you go double din, the JDM kit is the only one that really looks clean. I haven't heard any feedback on single din kits.
Old Jun 19, 2007 | 10:07 AM
hoser813's Avatar
hoser813
do you have a link to the metra harness?
Old Jun 19, 2007 | 11:18 AM
btorok's Avatar
btorok
I'm pretty sure Circuit City carries them. They're pricey for a harness (around $80-100), but the only one that works without extra cutting and splicing.
Here's a link with some more info from .net
http://my.is/forums/f103/how-semi-co...nstall-331788/
