IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Navigation retrofit
Old Feb 6, 2007 | 03:14 PM
a4_turbo's Avatar
a4_turbo
Default Navigation retrofit
Hey guys,
I am new to the this forum. About a year ago I bought an IS 300 SportCross and I'd like to start modding it.
Excuse my screen name - I just dont want to have a tons of screen names on different forums. If you feel like flaming go ahead. It is true, I am more of an Audi guy but so far the two cars are good friends and keep each other company in the garage. ;-) So if they can get along - why can't we?
One thing I'd like to add would be a navigation system - ideally OEM and then add bluetooth to it.
The next one would be to turbocharge the engine - I am afraid I will get lost here in the offerings.
Once I get to that point I will ask this community's help - until then maybe you can help me with the nav retrofit questions.
Is it even possible and how expensive will it get?
thank you in advance.
Old Feb 6, 2007 | 10:31 PM
SDLexus's Avatar
SDLexus
Anything's possible, but from what I've read in the past the expense wouldn't be worth it. Your best bet is to buy an aftermarket deck with NAV.
Welcome to CL.
Old Feb 7, 2007 | 01:31 PM
partynmyis's Avatar
partynmyis
I have the navi, The navi in the IS isnt all that good, The only reason i like navi is because you can control the climate and audio controls from it, but in the IS you cannot.. Its okay for when you get lost but i mean how often does that happend.
Old Feb 7, 2007 | 08:42 PM
a4_turbo's Avatar
a4_turbo
Got it. I have the nav in the A4 and with the Bluetooth combo is an awesome toy.
I'll look at some aftermarket solutions unless I get other encouraging news.
Old Feb 9, 2007 | 06:38 PM
sleepy's Avatar
sleepy
OEM NAV isn't that bad. My friend has an aftermarket system with touchscreen and other fancy stuff, but even then I still like the OEM system better.
There are some nice integration features you get w/ OEM system. The NAV gets speed and steering signals from the car so it can guess your car's position even when GPS signal is weak. It's also connected to the car's light sensors, so the display changes color and brightness to make it easier on your eyes.
And you can use it to control audio if you install the voice command module
OEM NAV is also pretty intuitive. My friend's Pioneer system is a mess. It has a button called "ESC" to go from audio menu back to the main menu... what is this, MS-DOS?
But it's an old system so there is no Bluetooth integration. You need to look elsewhere if this is important to you.
Old Mar 1, 2007 | 04:11 PM
03isfkr's Avatar
03isfkr
ive been looking at the oem nav myself but just the housing. alot of guys take out the screen and put in dvd screens. i think it makes for a clean install. there are guys who did the whole thing but it was like 1k. surf my.is and you will find lots of info. btw let me know when you want to sell your rear wheels
Old Mar 1, 2007 | 04:34 PM
Carbon~IS's Avatar
Carbon~IS
I don't think anyone has done the oem nav... It uses your stock amp so when you install aftermarket headunit, it makes it alittle more complicated.
Old Mar 5, 2007 | 12:25 PM
oddrob's Avatar
oddrob
It also has it's own specific wiring harness, another pain in retrofitting.
Old Mar 5, 2007 | 03:33 PM
jojor512's Avatar
jojor512
most dealers won't even quote you for retrofitting OEM nav, its that much of a PITA to do. possible yes, but it makes no sense $$$ or time wise for what you end up with.
what you could do is build the factory nav housing (~$220 unmotorized) and fit a 7" screen of your choice in there. a double din unit won't fit, but the screen will so you could either use one with RGB inputs for an external nav system or use a carputer with nav software on it.
or you could get the JDM double din dash kit and install something like the new pioneer D3, that way you get nav, dvd, xm, sirius, ipod, etc... with a close to stock look, plus its a lot easier to use a touchscreen right by the shifter esp. if you have a 5MT.
or you could just spend 1/5 of the $$$, get a tomtom and call it a day, thats what I ended up doing. plus its nice being able to take it from car to car and use the PC interface
and as far as turbos go... boost isn't cheap. if you do it cheap you're going to have problems IMO. do the research, get a reputable kit from a reputable vender, and pay the $$$$$ for proper tuning. don't expect to drop 5k on a turbo and call it a day, unless you really know what you're doing or have hookups, 7-8 is more realisitic if you're going to do it RIGHT.
EDIT: if you haven't already, register at my.is as well, it's far more active than here as far as IS300s go. lots of good boost info and nav info in the stickies there.
Old Mar 5, 2007 | 05:02 PM
96gti2.0t's Avatar
96gti2.0t
WTF this is clublexus get a new screenname. j/k
Old Mar 6, 2007 | 12:31 PM
Carbon~IS's Avatar
Carbon~IS
At least he doesn't have a picture of it in his avatar
Old Mar 22, 2007 | 02:52 PM
chunlew's Avatar
chunlew
go w/ eclipse by fujitsu ten, i hav the 5435, and man it was great!!!
UncleMitch
15
Nov 24, 2018 11:23 AM
JerryKK
Dec 25, 2012 08:55 PM
Asiatic
Dec 20, 2012 10:23 PM
KneeShoe00
Oct 23, 2006 03:38 PM
