IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
stalling while coming to a stop
Old May 29, 2001 | 09:40 PM
marcdall
Guest
Posts: n/a
Thumbs down
my car has just over 1,700 miles and today it stalled twice while coming to a stop. the car started right up but i am confused as to what the hell is going on. might it be related to the ecu problems. i need help my dealer thought i was smoking something
Old May 30, 2001 | 01:51 PM
EmoDragRacer's Avatar
EmoDragRacer
well I dont know how htat could happen does not sounds good.... ask them to run some diags on your car too see if they can find something in the log in your computer..
Old May 30, 2001 | 03:21 PM
Black_IS300's Avatar
Black_IS300
Ive had my car do the same thing but it would even stall while on the freeway... after taking it to the dealer they said that there was a short in the battery. They replaced the battery and it hasnt happened since
Old May 30, 2001 | 06:51 PM
marcdall
Guest
Posts: n/a
Default stalling
i did some further studying today and it seems as if the car either has the idle set to low, or the car is not downshifting quick enough allowing the rpm's to dip too low. my car idles around 500-700 rpm, does that sound right
Old May 31, 2001 | 06:03 AM
RealMarty's Avatar
RealMarty
The 500-700 rpm idle is in the right range. To me it sounds like the problem is that the computer is allowing the rpm to fall too low when the accelerator pressure is removed quickly. So it's dropping below the 500 rpm mark which causes it to stall. Carburators used to have a valve that stopped the accelerator from dropping too fast. Today it's done by computer.
Whether you smoke funny cigarettes or not the car shouldn't do this.
Sounds like a trip back to the dealer and a warranty repair is in order. If the service writer gives you a hard time just start ask to see his boss or the general manager until they address the problem.
knguyenk
Mar 9, 2013 01:15 PM
lowkeySC
Jun 15, 2009 12:47 AM
acenase
Jan 16, 2009 07:48 PM
92S0ARER
Jan 11, 2007 06:16 PM
hokietech
Apr 18, 2001 10:17 PM
