IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Crank no start, Intermediate Injector Pulse.
Old Jun 15, 2025 | 12:27 PM
EthanFr's Avatar
EthanFr
7th Gear
Default Crank no start, Intermediate Injector Pulse.
Hey guys, I’m new here, I’ve had my Is300 for about a year now I’ve rebuilt it (Pushing 270 cylinder psi dry) and made it look nice. Just recently I was driving it when it Has decided to shut off while driving… Strange… Got it towed to my house. sprayed Starting fluid in intake and it ran Just bad ofc. I then went to check if my fuel pump was working… I head it hum and took off the feed line to engine and put a hose there to see if pump out gas. I then rented out a noid light to see what the injector pulse looks like. Needless to say it’s random; sometimes it’s nice and bright, then no light, then dim light on all 6 injector plugs.. I have replaced my Crankshaft position sensor and still no luck.. I’m leaning towards bad Ecu.. Also all fuses related to fuel and spark have been good, I checked them all. Down below is a video of my car attempting to start, and the noid light situation.
File Type: mov
File Type: mov
Old Jun 16, 2025 | 03:10 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
Make sure your IGF signal is not being loss do to bad connections or coils.
Old Jun 16, 2025 | 03:13 AM
EthanFr's Avatar
EthanFr
7th Gear
Isn't that the b+ wire that goes from the ecu to the igniter to Coils, and 02 sensors and all that? I checked the voltage and it’s steady 11.34 volts
Old Jun 17, 2025 | 04:41 AM
2001SolarY's Avatar
2001SolarY
Yes I think so, But you need to make sure where the drop comes from. So check from the coils back.
Old Jun 17, 2025 | 04:46 AM
EthanFr's Avatar
EthanFr
7th Gear
I checked it it’s getting good voltage… Changed my camshaft position sensor too still nothing, Injectors still get intermediate pulse. I’m pretty sure it’s the ecu because occasionally I get no communication on my ecu while i got my scan tool attached… It also says my injectors are pulsing at 30Ms or so but doesn’t pulse.
Old Jun 18, 2025 | 04:54 AM
2001SolarY's Avatar
2001SolarY
Communication issue is usually a fuse issue. You could try replacing the igniter. Have you seen that the coils are firing? I also assume you checked the crank sensor wheel.
Old Jun 18, 2025 | 05:11 AM
EthanFr's Avatar
EthanFr
7th Gear
Default Fixed
I figured it out, Turns out it was the fuel pump… Which is strange because i swapped it out with another oem lexus one and it didn’t want to start.. Got that walbro 255 fuel pump.. Now it sounds cammed 😆😆
File Type: mov
Old Jun 19, 2025 | 02:41 AM
2001SolarY's Avatar
2001SolarY
You have other things wrong now.
Old Jun 19, 2025 | 04:46 AM
EthanFr's Avatar
EthanFr
7th Gear
Turns out It was my Vvt solenoid. It like failed or something and gunk built up in it
KazumaUCF20
Jul 2, 2024 07:27 PM
4400crain
Jun 11, 2022 07:20 PM
nsjuice
Oct 14, 2016 04:55 PM
Daegory
Nov 19, 2013 12:03 PM
PHASHAC
Jul 14, 2011 10:28 AM
