IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Engine Code 0355
Old Apr 21, 2025 | 05:20 PM
2003ES300user's Avatar
2003ES300user
1st Gear
Default Engine Code 0355
Received an engine code 0355. If the coil and spark plug have been replaced, I read it's the wiring or the ECM as the problem. Any tips on checking the wiring, please? If ECM is bad, would that reflect all
cylinders misfiring? Or does the ECM somehow isolate cylinders individually? I would prefer not to replace the ECM if I don't need to. Thanks!
Old Apr 22, 2025 | 03:07 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
Well in this forum for the ( IS ) model the 355 would be a bad coil. You should ask the ones for your ES model.
Old Aug 20, 2025 | 03:00 PM
DanielleAlek's Avatar
DanielleAlek
Wiring is religiously bad on these engines.
The main thing that goes bad on these ignition coil wires is the plugs themselves, which makes diagnostics pretty easy. On mine, the plugs were straight up missing, and the previous idiot just shoved the wires into the coils. Yours might be more subtle, like the clip is broken but didn't fully come off, or there's damage to the wire as it goes into the plug housing, or something of that sort.
ants99
Jul 18, 2022 08:10 PM
ameer90
Jul 16, 2021 07:27 PM
Max Power
Aug 24, 2009 04:06 PM
babyduke
Mar 5, 2007 06:56 AM
