IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Lexus IS 300 2003 code P0010
Old Jun 23, 2024 | 11:42 PM
raytorres66's Avatar
raytorres66
2nd gear
Default Lexus IS 300 2003 code P0010
Hello, I have a 2003 Lexus IS 300, I got code p0012, after changing the cylinder 1 injector, because the mechanic hit the selenoid camshaft connector with his arm, I already realized that the wires were broken, I soldered them and the tubing, already then the code p0012 went away, but now the code P0010 comes out, check the oil is fine, the timing chain was changed 2 years ago original and water pump, the code remains stored in the I take it out and the engine light doesn't come on but when I do the diagnosis the code comes up on the scanner in the stored area. I don't know if it will be the camshafts selenoid that I had stored 3 years ago and I bought it in California through eBay, and I say it will be damaged, What do you suggest, thank you, sorry for the long message but I wanted to be as exact as possible so that you could understand my problem.
Old Jun 23, 2024 | 11:49 PM
raytorres66
2nd gear
Dan300
May 9, 2025 12:44 PM
lexusisgs
12
May 18, 2023 01:38 PM
jasawh
Feb 24, 2018 06:29 AM
diverchris
May 1, 2014 01:20 PM
