Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Lexus RX450h water pump and spark plug replacement
Old Feb 17, 2023 | 11:06 PM
lexusisgs's Avatar
lexusisgs
here is my problem ,I wasnt able to replace sparkplugs because heat recovery unit was on the way for last 2 spark plugs .Small studs on the flange side were rusted and impossible to remove in order to get accesss to last 2 spart plugs,This one was ***** s...t I dont understand why hear recovery unit was placed right there above sparkplugs.On my es heat recovery unit is under catalic convertor not obstructing any thing.I will post picture and procedure detailed with pics how job was done including serpentine belt replacement with pisc as well
Old Aug 14, 2023 | 12:50 PM
CaptStumpy's Avatar
CaptStumpy
I just had the same issue. I needed to use a lot of heat and an air chisel to separate them. Finally, one bolt came out with an extractor socket, and the other snapped off. So I just reconnected it with one bolt. So far, its OK, no codes.
Old Aug 14, 2023 | 12:54 PM
CaptStumpy's Avatar
CaptStumpy
Top: 170,000 miles (has yellow + mark on the tip)
Bottom: New iridium plugs
Beastman
Maintenance
Aug 23, 2020 02:18 PM
myculito
Jul 13, 2018 08:15 PM
andy350
Oct 8, 2013 06:47 PM
vnairp11
Apr 24, 2013 08:54 AM
sqa4life
Aug 21, 2011 05:08 PM
