Hybrid Technology Unique topics related to the 2022 and up NX hybrid drivetrain and other features/options found only on the NX Hybrid models. Please use the main forum for discussion about shared components with other 2nd generation NX models.
Oil change interval with EV plugin
Old Jul 15, 2022 | 08:42 PM
edgeucated's Avatar
edgeucated
Default Oil change interval with EV plugin
Normally for my cars I change my oil every 10k miles and filter every 5k miles. Since the NX450h+ is a plug-in, would it be safe to change oil filter every 10k miles?
I'm asking because I use the electric motor 90% of the time, therefore the ICE rarely gets used; would this mean that 10k miles is really only 1k miles on the oil filter?
Old Jul 17, 2022 | 07:26 AM
lsft's Avatar
lsft
That is a very good question. The dealership would say - yes you should change it as oil will still go bad over time. I don't have an answer for this and maybe we should as the Car Care Nut - AMD (Youtuber) as he may have a better recommendation.
I think it still makes sense to do the oil change at least once a year. I do have 3 years of service included in my extended warranty package, so I will still do the change since it's included.
Old Jul 22, 2022 | 01:40 PM
kindofblue's Avatar
kindofblue
Question % oil life left as a readout
Does the 45h+ not have a readout in settings that tells you % oil life left? Our Volt does and recommends oil changes every 2 years (or sooner depending on use) when using primarily the EV motor.
Old Jul 22, 2022 | 06:16 PM
nx450plus's Avatar
nx450plus
The oil service interval according to my 450h+ seems to be quite long. I changed the oil at 1700 km and it says the next interval is at about 15000 km.
I will change the oil at 5k, 10k, 15k etc as I always have done with my previous ICE cars even though I use EV mode often in the 450h+.
Old Jul 23, 2022 | 06:38 AM
lsft's Avatar
lsft
There is a readout, but that readout is just miles/km left to the setup KM driven to the next expected oil change. In Canada we are scheduled for an oil change every 16k km or 10k miles and it will just count down on any miles/km driven no matter it's EV or HV driving.
Old Aug 13, 2022 | 02:16 PM
denisp's Avatar
denisp
9th Gear
Yes I have the 450h and the dealer recommends changing oil once a year. Regular ICE engine without hybrid, change oil at least 2 times a year.
Old Aug 14, 2022 | 01:21 AM
xcoreflyup's Avatar
xcoreflyup
Id run the gas engine for at least 10 mile once a week, just to circulate the fluids.
Old Aug 15, 2022 | 01:10 PM
Dkaplan's Avatar
Dkaplan
I’ll be changing the oil every 3000 miles or six months, whichever comes first.
Old Jan 13, 2023 | 05:06 AM
Dunerking's Avatar
Dunerking
What model do you have? We have a 23 NX450h+ and can’t imagine any new vehicle running synthetic oil needing oil changes at 3k miles. That sounds like some 60-70’s muscle car standard oil intervals.
Our TDI’s (Cayenne,Audi A3 and Jetta all diesels) scheduled intervals is 10k miles.
Old Feb 7, 2023 | 11:13 AM
TheCDN's Avatar
TheCDN
Default listen to the Toyota Master Mechanic 'Car Care Nut"
I would honestly listen to the master on this subject 'The Car Care Nut' on YouTube watch this video and see what destruction will happen to your engine:
He also has a video showing you the result of a car owner that followed Toyota's advice and changed every 10k miles, see at 11 minute mark the cylinder wall scoring:
As this gentleman constantly says "oil is cheap folks" and another classic, 'you can pay me now or pay me later'. If you love and care for your car and want it to last a very long time as all Toyotas and Lexus vehicles can do if properly maintained, don't listen to the owners manual and do an oil change every 6 months or 5k miles at the very least. AMD actually mentions in the first video that the owners manual is an absolute minimum requirement to not void your warranty, but once you're past that it's completely your problem which this unfortunate owner of the Camry found out.
So EV or no EV if you have an internal combustion engine under the hood you need to do oil changes period. I have a 2022 NX350h and have followed this guys advice and had my first oil changed at 1000 miles and will be doing them every 6 months or 5k as well.
Watch his video on his own new Lexus GX460.
He shows you the metal and gasket sealer debris that can be found in the oil filter just after it's first 1k miles.
Old Feb 8, 2023 | 01:52 PM
Dunerking's Avatar
Dunerking
Thanks for the informative videos! Some good info.
I can see the value of the very first oil change(break in) at 1,000 miles…but to process with all of the following(synthetic oil)oil changes at 3,000 miles seems excessive. I plan to send in oil sample periodically for analysis and would expect good results.
Old Feb 8, 2023 | 07:18 PM
Dkaplan's Avatar
Dkaplan
Originally Posted by TheCDN
I would honestly listen to the master on this subject 'The Car Care Nut' on YouTube watch this video and see what destruction will happen to your engine: https://www.youtube.com/watch?v=xdNCnYHhEm8
He also has a video showing you the result of a car owner that followed Toyota's advice and changed every 10k miles, see at 11 minute mark the cylinder wall scoring: https://www.youtube.com/watch?v=TJhFAwFv-O0
Watch his video on his own new Lexus GX460. https://www.youtube.com/watch?v=ttRIRwIaNd0 He shows you the metal and gasket sealer debris that can be found in the oil filter just after it's first 1k miles.
I did the 1,000 mile oil change and will do the 5,000/6-month changes on my NX350h. I did 3,000/6-month with my 14-year old ISF and never had an issue with the engine.
Old May 31, 2023 | 03:59 AM
Dunerking's Avatar
Dunerking
Does the NX450H+ have a log of miles on the ICE and the miles of EV? I know my CTD will show hours and miles.
Old May 31, 2023 | 05:53 AM
nx450plus's Avatar
nx450plus
There is no information on how much total distance in EV or ICE you have gone. For a trip it appears for a few seconds after you turn off the car.
Old Jun 2, 2023 | 03:36 PM
E46CT's Avatar
E46CT
To be on the safe side, change it twice a year or every 5k. whichever comes first. as others said, run the engine once a week, get it hot, and run it hard. then put it away. rinse and repeat.
