Honestly, how bad is the CVT engine on hybrid models?
2nd gear
Trying to determine if I should buy a hybrid or a regular. Those that are already driving hybrid models already, please let me know how bad the CVT engine noise is from the driver seat. Once I drove a hybrid UX model for a week and its continuous buzzing CVT noise drove me almost crazy. Is the new NX hybrids as bad as UX? Please be honest since this will not be a cheap investment. I can test drive but I want to hear from those that has been driving for a little while daily. Thanks in advance!
It's not bad at all. The cabin is much quieter than my Ct200h was, so the drone isn't as pronounced. Doesn't bother me or my wife who drives it a hundred or so miles daily for her commute.
You really need to test drive it and gauge for yourself. I have zero issues with it, but I'm also used to Toyota/Lexus CVTs.
Quick clarification, Continuously Variable Transmissions - CVT don't make any noises,
you are certainly asking about the Internal Combustion Engine noise, right? We all grew
up expecting to hear a big burst of sound followed by a big rush of acceleration. Nice turbo
car may even give you a nice crackle of sound when you deaccelerate also!
IC engines all have a sweet spot in the RPM range that is most efficient, every spec sheet
lists the Torque Peak such as 295 lbs/foot @ 2100 RPM. Conventional stepped gear transmissions
attempt to keep the engine near that speed, lower RPM just creates heat, higher RPM just creates noise.
What may disturb you initially when experiencing a car with a CVT (there are non-hybrids w/CVT's) is the
sound(s) may not synchronize with the seat of your pants sensations. No engine sounds when accelerating
normally, sudden surge of unexpectedly high RPM not matched by your speed gains and then the disconnected
sensation while cruising as the engine stays steady regardless of speed.
Consider the throttle settings on a Jet Airliner, pilot sets the throttles to the most efficient level for the weight and
altitude the plane is going to fly in...and leaves them there. Roll out, rotate and climb out. Once up at cruise the throttles
are pulled back...and stay there till decent. I hope you can buy into the advantages and join us in enjoying the differences
that our Hybrids with CVT's provide. There are a variety of Hybrid specific sounds that you will hear also. The emission
systems pump up and relieve pressures, the Motor Generators MG1 and MG2 make a whirring or whining sound when
regenerating electricity while coasting.
B0077144 (05-11-22)
You shouldn't be driving a hybrid like a normal ice. Take your foot off the gas to allow rpm to drop into ev mode then just tap gas to keep in ev and repeat once engine comes back in to play. May sound involved but it's not.
Mrnovanova (05-10-22)
Two hybrids a ES and a RX. Hear nothing from the CVT. Interesting those that say shifting through five six eight gears etc is smoother than not shifting at all with a CVT. Would never go back to a ICE.
mcomer (05-10-22)
I am perfectly happy with my 350h. I test drove a 2021 Rav4 hybrid limited and the road noise was loud. The 350h is much quieter.
I find that at cruising highway speed, the electric motor works with the engine and is a smooth decent quiet ride. Is it silent? Of course not.
i was worried about the CVT but now my worries are gone. Being a modest driver with a light foot, this NX to me is smooth, quiet enough, has enough power and has great gas mileage. Getting about 41.9 mpg so far after 1800 miles.
but to make sure it makes you feel good. Try to test drive one. By the way I have the premium trim with 18 inch wheels. Also when in EV mode it is very quiet.
If I am driving down my street at 10 mph, and the car is warned up (what is the quickest way in settings to see how charged the hybrid battery is?) but it is NOT in EV MODE and I hit the button and it goes into EV MODE, why didn't it do this by itself automatically and this happens a lot, am I missing a setting or are they designed this way? I had a highlander hybrid for 7 yrs and it also would not go into EV MODE as often as it should have.
Why wont my 2022 NX 350H go into EV MODE anytime EV MODE is available?
B0077144 (05-11-22)
Just give the gas pedal a firm push and let go. It'll go into EV mode and gently press the gas pedal to maintain your EV state. Press too hard it'll go away. If your going downhill it'll tolerate a harder press. That's what works for me and I'm averaging 5.7L/100km or 49 MPG (Imperial).
CVT refers to a specific transmission architecture, like DSG, 6-10 speed slush box.....
And what does this have to do with the quiteness or smoothness of the CVT.
