'12 RX450h AWD - Acceleration Delay - passing, etc
When I am going down the road at say 60mph and decide to pass someone and put the accelerator to the floor - the vehicle accelerates - however - not as quickly as it seems like it could be... if I push the accelerator say 2/3rds or 3/4 of the way - it will accelerate more rapidly.
Same if I need to pull into cross traffic and need to accelerate quickly or just want to - it does the same.
My vehicle has 177,800 miles on it... bought it with 35,000 in December 2014.
Curious what others experience with their '12 RX450h AWD and accelerating.
Thanks
JC
1. Andy already mentioned fuel quality.
2. Air filter condition ... I hope you don't have the washable/reusable kind.
3. Weight in the vehicle.
4. Steering set straight or not.
5. Status of the traction battery when you want to accelerate [is it syphoning the power to charge the battery]
6. VSC on [I do not recommend to turn it off, but if it is on, you get choppy power to the wheels].
7. Does the vehicle roll without drag [hanging brakes], poor alignment, bad whees/tires?
The question I do have for you is ... is the vehicle behaving differently or it has always exhibited the same behavior?
You can always go the dealer used lot and test out another RX-450h
Salim
1. I filled up with premium fuel today... will see if it makes a difference.
2. i change the filter regularly - so in good condition.
3. n/a
4. straight
5. n/a
6. will check this
7. n/a
Thank you!
Part way into my second tank of Premium fuel… made a significant difference! It is like a different vehicle!! Solved acceleration issue and overall performance much better !!
I looked into the TRAK setting, it’s on unless I turn it off. I definitely turn it off in snow or ice, slick conditions. It is more dangerous with it on in those conditions.
Thank you!
Thank you!
Salim
