Hybrid Technology Unique topics related to the 2015 up NX300H model hybrid drivetrain and other features/options found only on the NX300H. Please use the main forum for discussion about shared components with other first generation NX models.
Undercoat
Old May 20, 2021 | 09:09 PM
Gramps7's Avatar
Gramps7
Default Undercoat
I was told that it is not recommended to undercoat a NX 300h because the gooey undercoating could cause an issue with some of the electronics or battery things. Is this true? Anyone have an issue having undercoating done?
Old May 21, 2021 | 07:52 AM
TechNut's Avatar
TechNut
Veteran: Navy
I have heard a similar story, but cannot verify. I have also heard that modern vehicles have better factory rust preventative treatments but can't confirm that either. I understand your weather is more extreme than ours, but I would also be a bit worried about what that extra weight would do to the fuel economy of a 300h. Do you know how many pounds a treatment would add? I'm just guessing that it could add a couple of hundred pounds, or the equivalent of an additional passenger for every single drive. Anyway, I can't answer your question but just adding a couple of additional thoughts.
Old Dec 10, 2021 | 07:22 AM
isorunner's Avatar
isorunner
I heard with new cars. If you want to undercoat do it before you drive it around. Otherwise, you may be tapping in dirt and grime that may do more harm.
Old Jan 9, 2022 | 09:59 AM
midcow3's Avatar
midcow3
Post Undercoating does not affect electrical or electronics
That is not true at all, undercoating acts as an insulator and not a metallic conductor of electricity. I personally don't think undercoating is necessary at all. In ordercars 10, 20 or so years ago sound isulation was horrible and undercoating helped keep out some of the road noise.
Old Jan 9, 2022 | 10:00 AM
midcow3's Avatar
midcow3
Post If you must undercoat do it right away.
This is true, if you are going to undercoat do it immediately. But undercoating is not needed.
swfla
ES - 7th Gen (2019-2025)
89
Jul 29, 2021 04:41 PM
RXGS
Mar 23, 2021 05:25 PM
zabone
Jan 3, 2018 04:02 PM
Schroeck83
LX - 3rd Gen (2008-2021)
Sep 1, 2017 02:32 AM
AZCOBRA
May 24, 2017 05:25 AM
