Hybrid TechnologyUnique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Pls offer some guidance c 1259 1310 . Car starts and shuts off in maybe less than a minute. wont run even in maintenance mode .heavy shudder then shuts off
c1259 1310 codes present. car starts and shut off under a minute later wont keep up. hard shudder and loud noise while engine is running.. also smell of fuel in engine room .. 80k
Possibly your Throttle body needs cleaning. I had something similar a few months ago and I took the throttle body out and cleaned it thoroughly....The codes are weird
car has been running 10/30 since i owned it 3 years.. Doubt oil is the issue the issue feels like a fail safe or limp mode issue. need an in depth meaning of the codes cant find any real info online.. at one point car shut down because of the excessive shuddering. it threw a rod and piston through the block so i replaced engine with a used one and the similar shudder and start and then shut off same codes .. so obviously issue is not the engine per se
Have the spark plugs ever been changed? Getting to the rear bank can be challenging. Maybe a high mileage plug causes a misfire? Just spitballing here...
yes sir thanks for the comment.. changed plugs,cleaned injectors ,checked coil packs . substituted cam and crank sensors,pressure regulator, air flow meter,throttle body from another working vehicle.
My wild guess is your hybrid battery is going south. Or, ECM went bad, what is rather new for Lexi. They have pretty bulletproof ECMs.
Bite the bullet and have it professionally scanned by Techstream. Otherwise, you'll be chasing ghosts and tossing money at unnecessary, guesstimate repairs.
Diagnose cause>.correct cause.
