Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
RX450h traction battery problem.
Old May 25, 2020 | 12:04 PM
ESh's Avatar
ESh
Default RX450h traction battery problem.
A friend of mine drives a 2010 RX450h and the dealer said the battery should be replaced, the quote is around 7 grand, and that's a no no.
What are the options? Is there any way to replace the bad cells?
Thanks.
Old May 26, 2020 | 03:55 AM
Stoodo's Avatar
Stoodo
There are companies that rebuild the battery pack for far cheaper than that. Do a search on Hybrid Battery remanufacturing.
Old May 26, 2020 | 06:09 AM
EastTNLex's Avatar
EastTNLex
Thanks.
Is your friend having issues with the hybrid battery? Has your friend tried various apps (Dr Prius is one) that may help diagnose the issue?
Old May 26, 2020 | 06:50 PM
ESh's Avatar
ESh
So today I took the car and I checked it with Techstream and here you can see the numbers:
The code was P0A80. After the reset I drove the car for 20 miles and everything looks normal.
Do you or anybody else see anything suspicious here? I would like to see those numbers from a non problem car. Thanks.
Old May 28, 2020 | 05:05 PM
ESh's Avatar
ESh
I took it apart, cleaned all the contacts and it works much much better. I will drive the car tomorrow so I will keep you posted.
Old May 29, 2020 | 10:26 AM
Droid13's Avatar
Droid13
Neat. I've seen videos on Youtube doing battery disassembly on Prius batteries, and I recall at one point it was mentioned that corroded contacts often cause battery faults. Apparently you can even buy 3rd party contacts to replace instead of trying to clean them. For Toyota, I guess they want nothing to do with people messing with their batteries so the official story is always replace the entire thing even if a few bucks and a bit of TLC can often fix issues.
Gyuri
Hybrid Technology
14
Dec 17, 2022 04:40 PM
barouk
RX - 1st Gen (1999-2003)
Apr 6, 2020 10:35 AM
LSuxury
Aug 7, 2015 01:16 PM
Capirato
Oct 22, 2009 07:48 AM
nysupraman
Sep 5, 2004 06:05 AM
