Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Just got a 07 RX400h
Old May 20, 2019 | 07:29 PM
samwlexus's Avatar
samwlexus
Originally Posted by adibee
I have actually already purchased that too after doing some research. Still have not gotten the chance to do it. I should do it soon...But here is my purchase list for future reference( Cost was about 450$):
Timing Belt
- Timing Belt, Water pump kit W Tensioner
- Camshaft seals X 2 Toyota 90311-38034
- Crankshaft seals X 1 Genuine Toyota 90311-40022
- CVT Fluid
- Radiator Fluid
Spark Plugs Replacement
- Denso (3297) SK20R11 Iridium Spark Plug
- Toyota 12204-20040, PCV Valve
- Genuine Toyota 17176-20020 Air Surge Tank Gasket-
- Fuel Injection Plenum Gasket Stone 17127-20010
- Lexus 17116-20010, Fuel Injection Throttle Body Mounting Gasket
- Genuine 22271-20040 Fuel Injection Throttle Body Mounting Gasket- 8.36
- Denso 6731301 Ignition Coil 56.57X3 (For the rear)
I too am in your boat. About to buy an 06’ RX 400H with 170k miles. Very well maintained.
Just worried about the hubrid battery or abs brake issue. What were your thoughts there?
Old May 21, 2019 | 05:49 AM
mnewxcv's Avatar
mnewxcv
check the service history on Lexus drivers. An 06 would have been affected by the actuator problem, so it may have already been replaced. The hybrid battery is a risk anyone takes buying a 10yr old Lexus hybrid, camry hybrid, prius, etc. But a small number exhibit failures.
TDC1
GX - 1st Gen (2003-2009)
13
May 15, 2019 02:20 PM
PLAYTYM
Jan 7, 2011 12:16 PM
