Rear deck speaker
Rear deck speaker
I have a 07 GS450h. My rear deck speaker went bad as they all do with age. I have the ML 10" woofer. Its a pain in the buu to replace. You have to remove the upper side trim on both sides.
Anyway, at first I was going to just re-cone the ML woofer because of the shallow depth (Ventilation tube) below. However I got an audio guy to install a 8" high quality woofer with a huge magnet. It was wired in at 4 ohms. He had to make an adapter ring for it out of wood.
IT sounds 10X better than the factory. He charge only $50 because he knew me and also because he charged me $150 to install a blutooth connection so I can stream music from my phone wirelessly.
hope this helps someone.
