Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
2007 RX 400h Serpentine belt
Old 04-23-18, 09:27 AM
JumpinJohn
JumpinJohn's Avatar
Default 2007 RX 400h Serpentine belt
Hi. FIrst yes I have been searching the forum and googling for an hour.
No issues. Everything has been working in the car. I do believe the CEL has been on for a very long time.(moms car)
Doing an oil change, and upon inspecting belts, I don't see any!
I see two large serpentine pulleys on the crank.. I'm looking, but really can't see any other devices with pulleys
. Is it possible this vehicles doesn't have any external belts?
After searching I get more confused.
Does the RX450h share the same engine parts as the GS450h? More so than the rx 350-400s?
I'm not sure the belt diagrams I have located are correct either. If anyone has the proper one or a link? I'd appreciate it.
Are there any service manuals online?
Old 04-23-18, 09:38 AM
JumpinJohn
JumpinJohn's Avatar
Default Also does should it have a crush washer?
I am not sure if there is something on the drainplug. It looks black, but cant remove it. I have crush washers from Hondas that are a little bigger. Should I use them or go without anything?
Old 04-26-18, 07:53 AM
thomas1
thomas1's Avatar
First of all there are no belts external on hybrids....pulley is just the non used portion of this engine which is used thru out Toyota/lexus line of cars. Replace the crush washer on your drain plug with new. it is aluminum with felt washer .
Old 04-28-18, 06:24 PM
ukrkoz
ukrkoz's Avatar
Actually, my 2012 HiHy, which is same power train as RX hybrid, had ONE belt. Water pump. Far I know, even 2018 model has same belt. I am pretty sure you also should have it. It's called auxiliary belt or drive belt 99367C0810 $22.63
V6-3.5L (2GR-FXE) Hybrid
Old 04-29-18, 04:46 AM
smassey321
smassey321's Avatar
The water pump is turned by the timing belt for the 06-08 RX400h. There is no accessory belt. Just the harmonic balancer which has a pulley on it which is not used.
Old 05-04-18, 05:20 PM
jooksing82
jooksing82's Avatar
My demise is your gain! Here is a picture of the timing belt and the water pump. This is the only belt as stated.
Old 01-25-23, 06:06 PM
Dream450H
5th Gear
Dream450H's Avatar
I think air-conditioning compressor is electric so no belt. Water pump is driven by timing belt, probably why this one still has timing belt and not chain.
SJM (02-01-23)
javalogica
11-17-14 02:24 PM
jer
08-02-13 09:55 AM
noz34me
11-18-12 07:26 AM
mreinhard
10-12-12 05:11 PM
kentrx1
07-11-12 09:45 PM
Quick Reply: 2007 RX 400h Serpentine belt
