GS 300h hybrid battery never full
Hi,
I just bought a 2015 GS300h.
I have noticed that the hybrid battery never charges to beyond 75%. (6 bars out of 8).
Is this normal or should I be worried?
Im2bz2p345 (04-15-18)
If you turn off the AC you will more likely see it charge up to full. Most of the battery power is generated from braking is what helps you hit the 7 or 8 bar mark but your AC also consumes a lot of it. I would also say even if you just watch your car high 8 bars, it's actually only at 80% full, But your car will readjust and expel more power from the electric motor and thus save you gas.
When driving in city, and with the drive mode to normal, the battery will mostly be around 2 bars in the morning. This way the engine will have plenty of charging possibility to do to heat up quickly.
In eco-mode, the battery seem to be at a higher charge in the morning, to have more eco-saving potential maybe?
I saw these 2013 specs:
THE FACTS
Lexus GS300h
Engine/transmission: 2,494cc petrol engine, electric motor powered by a 1.3kWh nickel-metal-hydride battery, continually variable transmission, rear-wheel drive
Price/on sale: From £31,495/now
Power/torque: Petrol engine: 178bhp @ 6,000rpm/163lb ft @ 4,200rpm
Electric motor: 141bhp/221lb ft
Total system output: 220bhp
Top speed: 118mph
Acceleration: 0-62mph in 9.2sec
Fuel economy: 58.9mpg/60.1mpg (EU Urban/Combined). On test 49.6mpg
CO2 emissions: 109g/km
VED band: B (£10)
THE FACTS
Lexus GS300h
Top speed: 118mph
VED band: B (£10)
Don't worry absolutely normal @ 6 out of 8. Sometimes mostly in sport+ with more aggressive driving i get 7 out of 8 and in 6 years of having the car I've seen twice 8 out of 8
Im2bz2p345 (09-10-19)
Is that a possibility of getting 8 bars or do you actually get 8 bars often?
I've only seen a full 8 bars when the car is warmed up, car is charged a lot, and I hit some down ward sloping hills. Very rare in TX.
But man, the car really kicks when the batteries have a lot of charge! You can feel the difference in torque.
~ Im2bz2p345
~ Im2bz2p345
The car favors electric power when the battery is full because it needs to dump the charge quickly so you can regeneratively brake again. Also better for the battery to not be at a high state of charge.
Sometimes I dream about building a lithium ion replacement pack for the NiMH one and have it report "full" to the ECU so I get the high electric mode for longer.
The car works very hard to not get to 8 bars full though so don't worry if you never see it.
