Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
RX400H Yr 2008 - Center Storage Console "Close" Button won't pop back up
Old Jun 10, 2017 | 05:47 PM
nlayla's Avatar
nlayla
Default RX400H Yr 2008 - Center Storage Console "Close" Button won't pop back up
Hi, Can anyone help me? The "close" button won't pop back up when my console is closed. It only pops back up when it's open. See pictures. (please excuse the dirty car, I'm taking it in for detailing soon)
I tried using pliers to fork it out but that didn't help...Thanks! - Layla
Attached Thumbnails RX400H Yr 2008 - Center Storage Console "Close" Button won't pop back up-resized_20170610_172921.jpeg
Old Jun 11, 2017 | 08:53 PM
HtownBlue's Avatar
HtownBlue
You need to use a pick or a very small screw driver and pry and lift it back up. It will pop off most likely. Exposing a spring and the plastic rod at the base that is the trigger. You need to line up the grooves on the side of the now popped lit button with the corresponding slots in the space. All while carefully placing the spring around the trigger mechanism and sliding the circular shaft at the bottom of the button into the corresponding circle that surrounds the plastics trigger.
Old Jun 21, 2017 | 10:01 PM
nlayla's Avatar
nlayla
Thanks. I popped it up. Now I'll try to figure out how to put it back. lol
Old Dec 5, 2017 | 08:20 AM
drebeats's Avatar
drebeats
Has anyone had any luck replacing their center console with a used one found online? I'm looking at replacing mine, wanted to know if it was worth the trouble. Thanks!
Old Aug 10, 2019 | 01:49 PM
MJC59's Avatar
MJC59
Default I I am missing the “open” button on my RX 400h.
I am missing the “open”button on my 400h RX console. Does anyone know where I can buy a button?
i have found a new console. Before I buy, can I install this myself? How do I do it?
Old Aug 14, 2019 | 03:53 PM
rlnelson5's Avatar
rlnelson5
you need to clean the track spring and slots
someone has spilled coffee or soda on it and that makes it sticky .Try some hot water or contact cleaner Then some wd 40 or similar
ratha67
Oct 5, 2022 10:37 AM
Randyp1234
RX - 3rd Gen (2010-2015)
14
Jan 21, 2018 12:20 PM
gkgdawg
Nov 9, 2017 04:20 PM
Cheney
Aug 23, 2010 07:20 PM
kyleyjohns
RX - 1st Gen (1999-2003)
Jun 16, 2009 05:45 PM
