Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
RX400H - test mode issues & cannot initialise and calibrate linear solenoid valve
Old Jan 21, 2019 | 11:23 AM
j9ffy's Avatar
j9ffy
Default RX400H - test mode issues & cannot initialise and calibrate linear solenoid valve
Any insight appreciated!
Issue:
Flat 12v ancillary battery - vehicle won't enter ready mode, with VSC/HYBRID warnings. Replaced ancillary battery with new, fully charged, battery.
Vehicle still won't enter ready mode. Seen this before, so hooked up to tech stream, attempt to clear codes (usual C1259/C1310 on the VSC side and raft of Hybrid codes). VSC and Hybrid warnings come back immediately.
I've corrected this before by clearing store, zero point reset and then initialising and calibrating the linear solenoid valve. However, the reset does not work this time ... the ABS light blinks and I can hear the actuator making noises, but the brake control warning light remains on without blinking at all.
I've also tried the same clearing and calibration process using a jumper between TS and CG, but exactly the same result.
In Test mode in Techstream, I can toggle the warning lights on and off, the pedal stroke sensor is in range and functions, and I can toggle the abs related relays on and off. However, I cannot enter test mode to interrogate any of the solenoids or related tests (?!).
I've tested the abs module pinout resistances and everything is in spec. The can bus is not returning any dtcs and all modules appear in the can bus page of tech stream.
Incidentally, I notice that the scss solenoid is "on" from the get-go (no brake pedal press). Is this correct?
Any suggestions most welcome! My first thought is skids ecu has failed... or that maybe the scss solenoid is incorrectly defaulting on and this is causing issues... ugh...
Old Jan 21, 2019 | 04:35 PM
Nad1370's Avatar
Nad1370
Issue:
Go into HV ECU.
See what codes you have there.
I doesnt seem like its a VSC/ABS problem but could be a brake regen on the Hybrid ECU side.
Old Jan 23, 2019 | 02:51 PM
j9ffy's Avatar
j9ffy
Originally Posted by Nad1370
Go into HV ECU.
Thank you - great advice! This was a p3222 error and down to a loose connection into the mg ecu. Inverter temps MG1 and MG2 were open/ground so showing 150C.
I was thrown by having historically fixed same codes with a linear valve calibration - I suspect this was just luck and the loose mg ecu connection was causing intermittent issue.
Many thanks!! Regards, J.
Old Jan 23, 2019 | 08:19 PM
Nad1370's Avatar
Nad1370
You're welcome.
I always say, better be lucky that good. lol
Old Aug 17, 2019 | 01:28 PM
Rozay102's Avatar
Rozay102
Unhappy C1345 linear valve caliberation undone
even after replacement of skid control ecu and the brake actuator, resetting and relearning, i still have the c1345 code alone, withe the abs, brake and vsc error lights on the dash, any ideas would be greatly appreciated
bennecc
Hybrid Technology
24
Jul 4, 2024 11:10 PM
gsssss
Jan 23, 2023 09:57 AM
j9ffy
Jan 21, 2019 11:29 AM
acosta96
Oct 9, 2018 11:22 AM
AyyLS400
May 19, 2018 08:33 PM
