Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
Need to change oil myself 2013 ES300H
Old 02-26-16, 05:29 PM
KCES300H
KCES300H's Avatar
Default Need to change oil myself 2013 ES300H
All, we have a 2013 ES300H, we do all our own maintenance. Or we have in the past on our previous vehicles anyway! Hope to continue with that. Does anyone know how to change the oil in this vehicle? Thanks.......
Old 02-26-16, 06:59 PM
bc6152
bc6152's Avatar
Received 1,242 Likes on 872 Posts
The car takes a filter cartridge available by all major filter manufacturers or Lexus. There's two ways to remove the filter cartridge holder. With the cartridge comes a short hose that can be placed into the bottom of the holder after removing a small insert with a 3/8" socket wrench. This allows the holder to drain. The other way is to simply remove the entire holder with either a filter wrench or a cup type wrench that fits over the bottom of the holder. You do not need a special tool. After draining the filter it's oil change 101 - replace the cartridge, replace the cartridge holder, drain the crankcase, button it up, refill the oil and you're finished. If you search youtube there are videos.
Mobile 1 @ Walmart - 5 qts. $25.17.
Old 02-27-16, 04:09 AM
Freds430
Freds430's Avatar
Received 1,067 Likes on 695 Posts
Like to add every 10,000 miles you need an oil change and tire rotation. Every 30,000 miles the brake fluid needs to be changed. Every 20,000 miles change the air and cabin filters. This combined takes five minutes and the air filter can be bought on line at Lexus Parts World for $18 the oil filters are $4.50. The cabin air filter can be bought at Walmart for $18, It is the Fram Fresh Breeze #10285 with carbon and baking soda to filter the air. Wiper blade inserts again can be bought at Lexus Parts World for $20 for both refills and takes five minutes to replace. You are done until 100,000 miles. At Lexus Parts World use cl5 in the promo code for 10% discount. Once a year replace the key fob battery cr2032.
Old 02-27-16, 05:25 PM
KCES300H
KCES300H's Avatar
Can't find any ES300H specific you tube videos but did make some progress today, on page 830 (WOW that is a lot of owners manual!) it shows the hybrid model takes 4.6 quarts / 4.4 liters of 0W-20 oil.
And page 658 has instructions on how to reset the service indicator.....
Getting there!
Old 02-28-16, 09:39 PM
MrlexEd88
MrlexEd88's Avatar
Filters can also be bought at your local Toyota dealer as well. I highly recommend using genuine OEM filters.
Old 06-11-16, 03:31 PM
articaine
articaine's Avatar
Default oil filter
As the service interval is 1 year for oil change with full synthetic, does one need to get an extended life oil filter? If an OEM is not available, what else works?
Old 06-11-16, 05:52 PM
bc6152
bc6152's Avatar
There are numerous opinions as to the "best" filter to use on your Lexus. I use the Extraguard Fram which is the best in the Fram line. I found, at my first oil change, that the oil, even after one year, was so clean that I had difficulty reading it on the dipstick. Other members may recommend another brand. I've never used an OEM filter.
Old 06-11-16, 09:30 PM
zes
zes's Avatar
I have always worried that if one does the oil change oneself and something goes wrong with the engine during the warranty period the dealers will have an excuse not to honor the warranty.
Is it not better to swallow the bullet and get the oil change at least done by the dealer through the warranty period?
I remember years ago we had a Camry and always took it to the dealer for oil changes. At 62k miles (2k after the warranty expiration) one of the valve seals failed and the car started billowing smoke. The dealer looked at our oil change history and replaced the seals at no charge. Even made the point of telling me he was doing that because he did all the maintenance and could not fault us.
Old 07-28-23, 10:21 PM
SoCalh
4th Gear
SoCalh's Avatar
I would recommend the WIX XP version of the filter, the filtration media is specifically engineered to work with synthetic oil.
meffaman
RX - 3rd Gen (2010-2015)
26
08-22-19 04:59 AM
highvoltag
NX - 1st Gen (2015-2021)
17
04-17-18 07:58 PM
kambam3627
04-13-18 03:09 PM
fetv
ES - 6th Gen (2013-2018)
19
07-01-16 12:06 PM
Huynh9999
03-02-13 09:15 PM
Quick Reply: Need to change oil myself 2013 ES300H
