Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
"Check Hybrid System" Came on today!
Old 11-30-15, 04:07 PM
Champstar
Champstar's Avatar
Default "Check Hybrid System" Came on today!
My Check Hybrid System cam on, while I was driving. The car still drove, but only on battery power until battery almost ran out so I pulled over. CEL also cam on. I checked code ($10 obd tool came in handy). Code was P0335 Crankshaft Position Sensor A Malfunction. I cleared the code, and it started back up and ran like normal, and both codes were gone. I called a hybrid battery shop, and was recommended to only have it fixed if the Check Hybrid System light stays on. Has anyone had this experience? I will change my oil tomorrow because it is a 2000 miles past due. That is all I can think to do short of replacing sensors.
Old 12-01-15, 04:23 AM
Stoodo
Stoodo's Avatar
The shop is probably right. I've had codes pop up on my Camry Hybrid that I cleared and they never came back. Just be cautious and make sure you have a towing membership with someone.
Old 12-15-15, 08:56 AM
L8Apex
L8Apex's Avatar
I doubt the crank position sensor has nothing to do with the Batt. And yes, the 07 and early 08 Camry's are famous for the Position sensor code as well as blowing coil packs.
Old 12-16-15, 02:44 PM
tcr101
tcr101's Avatar
Might be something different, but I had a "check hybrid system" light come on my 05 prius (220k). It turned out to be the battery cooling fan was clogged with dust. Cleaned it out and it ran fine until I traded it in about 20k later. No idea if it had any other issues.
Old 12-25-15, 10:47 AM
Creolocks
Creolocks's Avatar
Default This came on today
This came on today. I have no idea what it means. All shop are closed today so I can't get it scanned. Please help! Thanks guys! Merry Christmas!
Old 12-25-15, 06:50 PM
rl9010
rl9010's Avatar
I am not sure what the problem is. It says that your car has traveled 138,746 miles and your hybrid battery level is at 3/4's providing drive to the drive wheels.
Old 06-07-17, 12:05 PM
samsonn25
samsonn25's Avatar
As long as the car runs and charges properly I wouldnt worrry.
My check hybrid light has come on before one time it lasted a few hours another a few days then went away. Car drove fine both times.
Old 06-07-17, 10:06 PM
rl9010
rl9010's Avatar
Looks normal to me. You have turned on the battery display that shows how power is being delivered or regenerated. If you hit the "disp" button on your steering wheel you will cycle through different information. odo is your odometer.
L8Apex
Hybrid Technology
19
09-13-21 05:21 PM
floradita
Hybrid Technology
07-08-21 01:47 PM
alexchris1
Hybrid Technology
18
04-26-20 03:35 PM
thisgtaguy
08-29-18 02:51 AM
aekhhi
06-27-11 06:55 PM
Quick Reply: "Check Hybrid System" Came on today!
