Hybrid Technology Unique topics related to the 2022 and up NX hybrid drivetrain and other features/options found only on the NX Hybrid models. Please use the main forum for discussion about shared components with other 2nd generation NX models.
NX450h+
Old Jun 6, 2025 | 04:45 PM
blueaquarius's Avatar
blueaquarius
1st Gear
Cool NX450h+
I just bought a PHEV yesterday and noticed that the car comes with a level 1 charger, which would take 12 hours to charge. I want to get a level 2 charger but I assume that I would need to get the Lexus specific one or has anyone bought a non-Lexus version?
Old Jun 7, 2025 | 03:08 AM
mtnman's Avatar
mtnman
The charger is in the car. What you're talking about is an EVSE, which is just the source of supply for the electricity.
No worries. The car will be happy with either level, 1 or 2.
Old Jun 7, 2025 | 09:05 AM
jelee's Avatar
jelee
I have the Battery Tender Level 2 charger which hooks up to a 220 V outlet that my electrician installed. Works great and charges way faster! It also has a 110 Adapter to work on 110 outlets but it downgrades to Level 1 charging.
https://www.batterytender.com/produc...charger-32-amp
Old Jun 7, 2025 | 10:53 AM
holmesm1's Avatar
holmesm1
Any 220 or 240 volt line will charge it much quicker than the 110 volt standard in most US homes. My wife has the NX PHEV and she uses my Tesla 240 volt charger all the time. It takes about 2.5 hours versus 12 for the 110 when fully drained. I used to use the 110 for my Prius Prime, charging it overnight. With a fully electric BEV, that is not practical, unless you don't drive very many miles between charges. A PHEV of course can run on gas when needed. I would have a qualified electrician install a home charging station, but that is a personal preference. BTW, some states have rebates/incentives for this. Mine, NC, has Duke Energy and they rebated the installation of around $600 for us.
Old Jun 7, 2025 | 03:47 PM
TechNut's Avatar
TechNut
Veteran: Navy
Any level 2 charger with a J1772 connector will work. I don’t even know if Lexus makes/sells a Lexus branded charger. I got an Emporia with a NEMA 14-50 electrical cable off Amazon for about $400. Works great. As others have reported, takes about 2&1/2 hours for full charge.
Old Jun 7, 2025 | 03:59 PM
StefanoS's Avatar
StefanoS
If you aren't ready to spring for a Level 2 unit at this time, the EVSE that was supplied with the vehicle is rated for both 120v and 240v. By simply using a plug adapter and using any of several 240v plugs, you can cut your charging time roughly in half, say 5.5 to 6 hours. If you have a 240v electric dryer outlet in you garage, this is a less costly means of charging your LiIon battery pack. The Lexus supplied EVSE is the same unit as used in Europe (with a different male plug) and other areas where electric current is 240v 50 cycle so, no need to be concerned about blowing anything out.
Here are two options for plug adapters, depending on your 240v outlet type:
14-50:
Amazon Amazon
10-30:
Amazon Amazon
I initially did this with my two PHEV's until I finally bit the bullet and purchased an Emporia EVSE on Amazon.
Amazon Amazon
Old Jun 14, 2025 | 06:18 AM
JimC's Avatar
JimC
Default nx450 +
I have an emporia because my wife has the plug in for her Rav4 and that works great, so you can purchase other brands, but check with your local electrician who installs car charges before purchasing.btw it chages my NX from empty to full in about 2.5 hours
Curated Content Editor
UX Models (2019-present)
Nov 22, 2023 08:33 AM
LiBeRtAs
NX - 2nd Gen (2022-current)
Nov 5, 2022 03:30 PM
*Batman*
15
Nov 28, 2011 06:08 PM
freddymoo
Aug 6, 2007 07:05 PM
