Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Engine and hybrid coolant low
Old Sep 15, 2024 | 10:31 AM
tobsie's Avatar
tobsie
Default Engine and hybrid coolant low
Both my engine and hybrid coolant are decreasing of my 2005 rx400h with 120k miles.
i noticed the radiator is not in the best situation at the bottom. So this radiator should be replaced.
I try to understand how it is working and in the below document I see it are separated cooling systems flowing trough one radiator. Is this also correct for the rx400h?
Pdf file
Reasoning is that both cooling systems are loosing coolant.
Old Sep 20, 2024 | 10:57 PM
tobsie's Avatar
tobsie
Nobody any experience on this topic?
Old Sep 21, 2024 | 02:02 AM
Lexicon1's Avatar
Lexicon1
How low is low ? When was the last time you checked both levels of coolant.
If you notice the radiator is defective, get it replaced asap, just keep an eye on the hybrid coolant level, but do check ALL hose connections looking for any pink powder around hose connections... use only Toyota Pink/Red coolant and do a flush, how old is the coolant , how often do you check fluids levels.... many questions.... has someone used non-toyota coolant., dont mix coolant brands due to different coolant formulations.... these are considerations to address
Old Sep 21, 2024 | 02:18 AM
tobsie's Avatar
tobsie
Thx. This is clear for me. My main question is, if the same radiator is used for the engine coolant circuit and the hybrid coolant circuit (like the pdf)? Or are the 2 seperate radiators?
Old Sep 21, 2024 | 04:43 PM
Hobbes22's Avatar
Hobbes22
They are separate. Both cooling systems use the same type of coolant. It’s not uncommon to have to replace a Toyota/Lexus ICE radiator every 8 or so years.
The ICE radiator P/N is 16041-20353.The inverter radiator is P/N G9010-48010.
Old Oct 17, 2024 | 09:18 PM
thomas1's Avatar
thomas1
I have actually replaced the radiator twice in my 2008 RX400h. they just dont hold up. One thought is if the radiator hoses get stiff from age they put more stress on the radiator, also the constant on and off of the engine. Make sure your upper strut motor mount is not broken also, as this allows more motor movement when cycling on starts.
vinster29
Hybrid Technology
13
Feb 7, 2024 07:50 AM
Lexus-SSA
Hybrid Technology
Jul 17, 2023 07:20 AM
jumbodrive
Mar 13, 2022 12:51 PM
TRW88
HS 250h Model (2010-2012)
Dec 12, 2018 12:18 PM
Brutus213
Feb 20, 2017 12:35 AM
