Hybrid Technology Unique topics related to the 2023 up RX model hybrid drivetrain and other features/options found only on the hybrid models. Please use the main forum for discussion about shared components with other fifth generation RX models.
Turn off "Next Charging Event" notification?
Old Sep 2, 2024 | 10:42 AM
deaded's Avatar
deaded
Question Turn off "Next Charging Event" notification?
Is it possible to turn off the Next Charging Event notification/pop-up? I have not set any charging events. The calendar is empty, yet this keep popping up and is a bit annoying.
This is in a new 2024 RX 450h+
Old Jan 6, 2025 | 10:35 AM
ChrisON's Avatar
ChrisON
10th Gear
Unhappy
I feel the same way. I get the notification and it is annoying.
Old May 22, 2025 | 02:55 PM
kevlo's Avatar
kevlo
1st Gear
Hi!
It might be a bit late, but if you are talking about the notification on the screen (14" screen), I got the same notification after a car maintenance at the dealership. I went back and they couldn't figure out why and how to fix it.
So I decided to do my own research, and discovered the ACC customize. Although I have a Lexus NX 450+ and not the RX 450h+, the system should be the same.
Here is how to no longer see the Next Charging Event notification on the screen by doing the following steps
(your screen will turn off when turning the car off, so you will no longer see the Next Charging Event notification):
  1. Go to Setting (gear icon)
  2. Scroll down until you see Vehicle customize
  3. Click on Vehicle customize
  4. Scroll down until you see Utility
  5. Click on Utility
  6. The ACC customize should be toggled off (gray toggle)
  7. Toggle the ACC customize on (blue toggle)
  8. When you turn the car off, the screen will automatically shut off too
Having the ACC customize toggled off, it allowed the user to use the screen when the car is turned off (until you open the door) as an accessory mode.
Old May 22, 2025 | 05:07 PM
deaded's Avatar
deaded
Thanks. So it's a trade-off. OK.
I appreciate you taking the time to share this information kelvo!
radajg
RX - 5th Gen (2023-present)
May 26, 2023 01:45 PM
TimHopkins
Aug 30, 2018 11:33 AM
k20trick
IS F (2008-2014)
Dec 7, 2015 08:44 PM
free_the_p
Jul 30, 2008 12:42 AM
