Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Hello all Lexus enthusiasts.
Old 05-23-24, 07:05 AM
steveintaiwan
6th Gear
steveintaiwan's Avatar
Default Hello all Lexus enthusiasts.
Hello all. I just got my new to me 2012 rx 450h. It’s got 115k miles on the clock. It’s quite a lot considering I’m in Taiwan. I don’t have any previous maintenance records, but it looked too nice to pass up. However, the big HV was changed 2 years ago, and I recently changed the oil, small battery, cvt fluid and rear motor fluid as well. The dealership here changes the fuel pump and spark plugs at 60k miles. Is that an overkill? I am on a budget, but I do plan on changing things in the future. Any advice is appreciated. Thanks in advance.
Old 05-23-24, 08:09 AM
steveintaiwan
6th Gear
I just purchased a new to me 2011 rx 450h with 115k miles on the clock. It’s quite a lot considering I’m in Taiwan. I don’t have any previous maintenance records, but it looked too nice to pass up. However, the big HV was changed 2 years ago, and I recently changed the oil, small battery, cvt fluid and rear motor fluid as well. The dealership here changes the fuel pump and spark plugs at 60k miles. Is that an overkill? I am on a budget, but I do plan on changing things in the future. Any advice is appreciated. Thanks in advance.
Old 05-23-24, 08:19 AM
RX in NC
RX in NC's Avatar
On the RX350, changing the fuel pump and spark plugs at 60,000 miles is indeed major overkill (and expense). I would assume that to be the case for the hybrid version as well.
steveintaiwan (05-24-24)
Old 05-23-24, 08:22 AM
steveintaiwan
6th Gear
Thanks so much for your speedy reply.much appreciated.
Old 05-24-24, 02:15 PM
salimshah
salimshah's Avatar
Received 1,036 Likes on 934 Posts
Congratulations on your purchase.
Aisa and NorthAmerica are different markets but =you should still get a warranty and service manual. If you don't have one ask the local dealership to get you that book. It will list all recommended services and if you want to overachieve, nothing says you can not or should not. Few things are typically different that driving around in NA would be the fuel quality. Here in USA due to environmental concerns the fuel is kept isolated and is much more cleaner than the fuel stored in Asia. [which are typically in an unsealed underground tanks] which gets contaminated by rain water and what ever it brings with it. Other issue is the vehicle are typically used for shorter run. So follow the service recommendation for adverse driving conditions.
One of the items which may or may not be listed would be ecvt fluid change. Although this transmission is different from RX 350, my advice will be to replace it at multiples of 65K miles in North America and 50K miles in Asia.
Salim
PS: Taiwan may be an exception from general conditions in Asia.
Old 05-24-24, 06:26 PM
steveintaiwan
6th Gear
Thank you for your helpful feedback.
Old 05-27-24, 12:36 PM
703's Avatar
That’s every high mileage. Don’t waste money on spark plugs or transmission oil.
get a coolant flush, both inverter cooling and engine. Then save your money for front and rear struts. They will go out.
steveintaiwan (05-28-24)
ath2010
09-17-22 07:15 AM
Rjkraz
07-07-17 08:35 AM
CRD
Hybrid Technology
10-08-13 03:33 PM
lexitaxi
RX - 1st Gen (1999-2003)
04-07-10 12:03 PM
Lexus Guy3
Maintenance
02-16-08 06:05 AM
Quick Reply: Hello all Lexus enthusiasts.
