HS 250h Model (2010-2012)
License Plate Bulb Replacement
Old Oct 28, 2022 | 09:48 PM
850R's Avatar
850R
Default License Plate Bulb Replacement
My license plate bulbs are getting pretty dim. I am thinking of removing them and possibly replacing them with LEDs. Has anybody replaced theirs? Does the trunk liner need to be removed in order to access the bulbs. Also, I was thinking of trying these bulbs: Zevo Led Bulbs Has anybody tries these models on you HS250h or other vehicle?
Old Oct 30, 2022 | 01:57 PM
Clutchless's Avatar
Clutchless
Here is the service manual chapter on the license plate lights. Hope it helps.
File Type: pdf
Old Oct 31, 2022 | 10:43 PM
850R's Avatar
850R
Thanks Clutchless, that helps a lot. After I get done, I will shoot another repair video on the bulb replacement/
Old Nov 16, 2022 | 02:25 AM
nacho121's Avatar
nacho121
New Member
Originally Posted by 850R
My license plate bulbs are getting pretty dim. I am thinking of removing them and possibly replacing them with LEDs. Has anybody replaced theirs? Does the trunk liner need to be removed in order to access the bulbs. Also, I was thinking of trying these bulbs: Zevo Led Bulbs Has anybody tries these models on you HS250h or other vehicle?GBWhatsapp
same problem faced me.
Old Nov 17, 2022 | 04:59 PM
850R's Avatar
850R
I just replaced my bulbs on a cold November day. My old bulbs were turning black and very dim. I installed a pair of Sylvania LED Zevo Lamps. A huge upgrade and difference over stock install. In order to help folks out I made a video tutorial:
deeisgram
Lighting
May 25, 2011 06:10 PM
dysLEXic
Mar 23, 2008 01:25 AM
mybadsc
Dec 6, 2006 09:00 PM
mxh3901
Nov 19, 2006 06:11 PM
