Front Struts Assembly - Found a solution
So - as a bunch of people have learned, the front struts, when they finally go, there's no good option to replace them. Yes - you can just buy the strut, but that's assuming that all your bearings, mounts, and your coil spring are okay AND you're willing to pay the extra labor to compress the coil to swap out the struts.
That's $1000 or more in parts and another few hours of labor. One shop quoted me $2200 since they were going to buy the parts from the nearest dealer (which would have been ridiculous).Struts do NOT cost $2200 to replace. Parts alone shouldn't run much more than $200 for the set, but here we are.
I live in NY state (Buffalo) - as you may know, we have harsh winters where salt is liberally placed all over the roads. I can't speak to how strong my bearings and mounts are - they likely need replacing.
But I found a solution that Toyota seems to have forgotten to link in their compatibility charts.
The 2011 Scion tC. This is a 2 door coupe, but much of the front end is similar to the Avensis/HS250h/Sai (and others).
So I looked, and not only is there a widely available assembly available (aftermarket, and from Toyota/KYB), but the assembly cost is very affordable.
I compared the HS diagram with the 2011 tC diagram. They're identical, part-for-part - the entire assembly. I talked to my mechanic and he did the research and he agrees with one exception - there is a single mounting plate that isn't present in the HS, but it's there in the tC...BUT - it's not related to the spring, so it's easily removed.
I know there are some discussions about the struts, and with those of us who still drive an HS (or happened to grab one recently - props to those who got one of those 34000 KM ones still available in Japan) - this will hopefully be helpful and will save you from buying $1000 in parts PLUS assembly labor.
OH -and remember to place your stabilizer links. They're probably rust-welded on, and changing out your struts is always a good time to change out your links.
EDIT: The 2012 Prius V assembly will also work - in case someone hasn't compatibility coded them properly.
The strut mounts to three parts of the car:
- steering knuckle
- upper strut mount
- stabilizer link
these three parts are actually identical catalog parts between the hs250h, the 2011 scion tc, and the 2012 Prius V.
Did they have to replace the stabilizer/sway bar link? Often they are rusted and have to be cut off.
The Scion TC (2011) assembly set not only cost less than the individual shocks (unassembled), but labor was a hell of a lot less. And it was KYB - so it's as close to OEM and high quality as I'll get without getting some custom racing set that I would never, ever need in this car.
I got separate Moog sway bar links - I probably didn't need them, but you never know if the bushings are all weak/torn apart until you take them off, then you at the very least need new bushings (which cost damn near what an sway bar link costs alone - kind of insane for a piece of what I assume is rubber sandwiched between washers).
It was a fantastic solution, and the car rides great.
Suspension Shock Absorber (Left, Right, Rear)
Part Number: 4853075032
https://parts.prestigelexus.com/p/Le...RoCf3cQAvD_BwE
With that said, unfortunately someone hit me in a parking lot. They hit my passenger side front, bent the axle, broke the strut, screwed up the fender, door, and bumper. The repair would have hit $7200, which is more than Insurance wanted to cover, so they paid me out $10k to total it and I'm now looking for another car.
It was a good run.
It was a good run.
Last edited by Errolflin; Jul 12, 2023 at 01:30 PM. Reason: Update regarding dealer parts order
Between 2013-2017 they sold an updated model, and then cancelled the type. Those parts are less likely to be compatible with the USA model.
For what it's worth... Here is just a search for "パネル" (panel)
https://buyee.jp/item/search/query/A...nslationType=1
Last edited by dougaliscious; Aug 8, 2023 at 04:38 AM. Reason: add additional illustrative information
