HS 250h Model (2010-2012)
Parking Assist Module
Old Mar 29, 2020 | 11:53 AM
Gx470blk's Avatar
Gx470blk
Default Parking Assist Module
Hi
do you guys know where is the parking assist module is located ? I look behind the glove box and under the dash and is not there ... Thank you
Old Apr 1, 2020 | 06:48 AM
Clutchless's Avatar
Clutchless
I have no idea, but if you hunt the parts diagrams at one of the online OEM Lexus parts dealers, their parts drawings should help you find it. A few of them are Lexus South Atlanta Parts, or MYLPARTS or Lexus Parts Now.
Or ask a body shop. What is your problem?
Old Apr 6, 2020 | 09:02 AM
Gx470blk's Avatar
Gx470blk
I notice that my car is pre-wire for parking assist sensor. I saw on this forum that most lexus are pre-wire and you just need to add the module, sensors and beeper. I already have the correct part number already. But to confirm I need to know if the harness for the module even exist. I did look at those web site and they are not tell you at specific location.
Old Apr 7, 2020 | 10:07 AM
Gx470blk's Avatar
Gx470blk
i figure it out, and found it behind the glove box. The module is not called park assist instead called clearance warning ECU. I just ordered the module and I will update if that works or not.
Old Apr 10, 2020 | 06:52 AM
Clutchless's Avatar
Clutchless
Good luck. I have and aftermarket parking assist system that was on the HS when I bought it used in 2013. Then it got rear ended and pushed into the car in front and the body shop replaced it with an even better aftermarket parking assist system. It has a little module on the left corner of the dash that tells you how far away you are from hitting something, and it beeps.
burnik
ES - 7th Gen (2019-2025)
Dec 23, 2019 02:17 PM
MnM24
Chicago Lexus Club
Aug 10, 2013 07:27 AM
BlitzSix
Mar 31, 2011 06:05 PM
Nov 1, 2009 11:00 AM
NesTea420
Mar 2, 2005 01:17 PM
