HS 250h Model (2010-2012)
Replace reversing camera
Old Apr 21, 2025 | 06:41 PM
DanNZ's Avatar
DanNZ
10th Gear
Default Replace reversing camera
The new high-resolution screen on the android unit I’ve installed in my son’s car is really showing up how cloudy the reversing camera is (the front camera is fine). It looks like new OEM replacements are not cheap - several hundred US$. There are third party replacements that are a bit cheaper.
https://www.ebay.com/itm/176336091434
A search on Aliexpress doesn’t bring up any cameras for the HS250h, but it does bring up one for the 2011 Toyota Hilux that appears to have exactly the same 4 pin connector as the HS250h:https://a.aliexpress.com/_mqDHMh5
I wonder if this camera could be made to fit the housing on the HS250h?
Does anyone have any experience with replacing these cameras? Any suggestions?
Old Apr 22, 2025 | 04:42 AM
dougaliscious's Avatar
dougaliscious
I really wouldn't bother trying to adapt the housing of the wrong part to make it watertight.
What worries me about the aftermarket camera you've referenced on EBay is, the product description doesn't say anything about the camera having greater resolution or dynamic range as the stock camera.
Have you tried just scrubbing the lens with a damp microfiber cloth? Maybe it's just dirty?
If you find that the lens is scored/scratched and that's the cause of the poor image quality, then try the $85 EBay item. It's probably identical circuitry to the original.
If you are absolutely sure you intend to get a reverse camera with better image quality than the original, then I'd start with the video input specifications for your new console video screen. Just bypass all the Toyota wiring, install the 3rd party camera somewhere suitable and wire it directly to the reverse video input on the Android device. What I'd expect with this however, is the parking guidance lines aren't going to line up correctly with the image.
Old Apr 23, 2025 | 01:18 AM
DanNZ's Avatar
DanNZ
10th Gear
Default Camera options
I've definitely tried cleaning the current camera to no avail. I've got some plastic polish that I suppose I could try too. I really don't want to install a CVBS camera, re-route cables from the boot through to the dash, and dismantle the dash again when a simple plug and play option is available. I don't think weather tightness will be an issue either - take a look at the attached picture - the Aliexpress camera *should* fit inside the mounting bracket of the original and I can always epoxy it. My main concern is that the "guidelines" that vary with the steering wheel angle might be off. Either way, I like a project and I'm keen to see if the Ali express one is any good at all. It cost me the grand total of NZ$30 - which is around GBP15, so I don't really care if it turns out to be crap!
danny8787
Oct 9, 2024 06:55 AM
MrLogan13
Sep 25, 2019 06:16 PM
Skyescoote
RX - 3rd Gen (2010-2015)
Nov 15, 2018 08:59 AM
Splsales
Nov 15, 2017 08:18 PM
RookieLEX
Jun 29, 2016 02:43 PM
