Lifting the GX460
Lifting the GX460
I am going to install my Radflo suspension with UCA's tomorrow. I was wondering what do you do with the module that sit on top of the front shocks? Would it trigger any dash lights if I remove the module. What does your wiring loom look like after the aftermarket shocks/coilovers are installed.
i think theres a thread somewhere on that, the best was to spin it around and keep it on there, else get an error if im not mistaken.
Super Moderator
FSM states front stabilizer bar has to be dropped in process... those who have done this will have to chime in as I am not sure. FSM instructions attached.
tecman (06-21-19)
I was able to install my suspension today without touching the KDSS at all. To lower the passenger side LCA, I placed a jack under the KDSS piston. To lower the driver side, I jacked the LCA of the passenger side. This method gave me enough clearance with some prying. Thanks.
Super Moderator
I will probably have to do something similar with jacks on my rear when I install my C4 rear diff skid.
