Pre-purchase inspection, error codes P-1603 & P-1605
When I purchased my truck a few months ago, my mechanic (well versed in Lexus/Toyota) saw the same codes and said it is very common..
What I have learned......
The most likely cause of the stored codes was changing the battery without using a OBD "memory saver" device.
Apparently it is common for Toyota/Lexus vehicles to loose throttle body idle settings when the battery is disconnected.
This may lead to engine stalling until control modules re-learn settings for the throttle valve idle circuit . Hence the engine stall code.
The owner reported that a new battery had recently been installed. Presumably by someone unaware, as I was, concerning use of a memory saver device.
This also explains her report of the engine having stalled while idling on her driveway.
This GX checked out fine otherwise But I was put off buying it due to chassis rust.
Guess I simply had not seen the underside of an older rust belt vehicle in a while. Yuck !
Top side looked very nice in all original paint.
Will resume my GX search in Florida next month
They are significantly more $$$ in the USA but at least I should be able to locate one with a clean chassis.
Thanks to all who contributed suggestions & advise !
But, of course, if you can source another truck from any of the southern states, that will be great. Also trucks from BC seem to have much less rust. I saw a couple around here for sale, but didn't buy them because they were offered by dealers (I never buy from dealers)
