#Cup #holder questions, comments, problems, mods
Old Sep 25, 2020 | 02:01 PM
  #91
Joeytoylex's Avatar
Joeytoylex
Default Cup holders
Have you spilled large drinks in your GX460?? I ordered this from Matt and it has been amazing.
https://crafted-by-matt.com/
Old Sep 25, 2020 | 04:12 PM
  #92
Acrad's Avatar
Acrad
I picked up one of those as well
[Post 71]
https://www.clublexus.com/forums/gx-...l#post10663519
Old Sep 25, 2020 | 05:04 PM
  #93
tecman's Avatar
tecman
I considered this option but I use the cup holder to store small items so I don’t think I could get my fingers in there.
Old Nov 3, 2020 | 07:31 PM
  #94
gmac0518's Avatar
gmac0518
how does this do with smaller cups or bottles? It doesn't appear to have arms or something to hold a 20oz.
Lexus should be ashamed of not having an easy replacement.
Old May 23, 2021 | 09:17 PM
  #95
Willcoop's Avatar
Willcoop
clearmysix if you still have your old cup holder laying around. Do you want to sell it?
I am trying to find the early style 460 cup holder and haven't found any other than new.
Old Dec 27, 2022 | 11:56 AM
  #96
Avmanager's Avatar
Avmanager
I know this is an older thread, but I was searching the Forum to see if anyone had a Cupholder recommendation to go between the 2nd row captains seats on the GX460. This is our second GX460 and somewhat surprised that they still have the same terrible design that was in my 2017. I love everything on the 2022 we bought a few months back but the cheap Captains chair cupholders. I remember Lexus having to replace one of them after a few months when I had my 2017, but would have figured they would have a cupholder to at least hold a Yeti 20oz Tumbler. I was googling and trying to find just a cupholder that sat in the floor between the 2 seats.
Old Nov 12, 2024 | 03:30 PM
  #97
GXRockies's Avatar
GXRockies
6th Gear
Originally Posted by craigrpete
An unknown object got lodged behind the door of my center console cupholder. I couldn’t open it all the way. After searching high and low for directions on how to fix it and finding nothing I dug into today. Pretty simple to do - here’s how I did it:
0) Car should be off for this whole process. I didn’t disconnect the battery
1) Remove the 2 leather trim pieces on either side of the console. These are just held on by tabs and came off easily. I started from the back and worked my way forwards toward the dash.
2) Remove the 2 bolts that were just exposed that hold the console to the dash assembly. These are 11mm bolts. On my vehicle the bolts were not screwed down very tight.
3) Open the center console bin (arm rests) and leave them open as the cupholder sits under the arm rests.
4) Remove the 2 11mm bolts at the bottom of the storage bin.
5) That should be enough to get every loose. First lift up on the silver trim around gear shift where it meets the cupholder. You should be able to lift it at least a half an inch. Now lift out the cup holder assembly starting by tipping up the front then the back - it should lift out at this point.
6) When you lift it out take off the light wire harness and the cup hold should now be completely free.
For those of you who are giddy with suspense it was at this point I found a ballpoint pen has slid down behind the cupholder door cover :-(. It easily shook out.
That at was it. Reverse the steps and I was back in business. What a pain!
Hope this helps someone else. Thanks.
Thanks for posting these instructions, I bought a '12 this past August (with only 45k miles) and soon after my cupholder lid wouldn't open all the way. Found your old post while lurking a few weeks ago and today had the time to get into it while following your instructions. Once I got the cupholder completely disconnected I shook out not one but two pens promoting businesses with the area code from the city where I bought it, so they had been in the car all along and took a while to get into the right position to jam the holder lid. Anyway, thanks for taking the time seven years ago to post your fix!
RPH74
GX - 1st Gen (2003-2009)
Jul 15, 2017 08:38 AM
glemmen
Sep 30, 2004 11:31 AM
