Bird chirping sound or squeeze
Old Jul 19, 2022 | 03:24 AM
Donhim's Avatar
Donhim
9th Gear
Default Bird chirping sound or squeeze
Hi all, I have a 2014 gx. I recently hear a bird chirping sound or squeeze when the car runs on a light bumpy road(or a little vibration). I want to see if anyone wants experience the similar issue. I don’t even know where the sound is coming from since it’s light. If it hit some serious bumpy road, it doesn’t have the sound. Strange. Mine has only 20k miles. Local mechanic says it should not have any issue since the mileage is so low. Appreciate any help. The sound can be annoying. Thanks!
Old Jul 19, 2022 | 06:43 AM
ballistice's Avatar
ballistice
How much off road do you do? 20K is a lot of miles if it lives a good portion of its life off highway. I would get the wheels off the ground and start checking the bushings, bearings, tie rods, hubs, and all moving chassis components.
Old Jul 19, 2022 | 06:47 AM
Donhim's Avatar
Donhim
9th Gear
no off road at all. Just grocery shopping
Old Jul 19, 2022 | 07:39 AM
NewB2Lexus's Avatar
NewB2Lexus
The low mileage with no off-roading pretty much rules out suspension parts. I would first look inside the truck and see if it may be coming from some loose items in the pockets, glove compartment, trunk etc.. Next, try to do a thorough undercarriage wash and make sure no dirt or rocks cause some rubbing somewhere. I would also check and make sure no rock(s) are stuck between the rotor and the protective wheel plate (this happened to us). If it is still there you need to start checking individual components as Ballistice suggested.
Old Jul 19, 2022 | 10:09 AM
IanB2's Avatar
IanB2
Try spraying the rear hatch door's latch and guides with WD40, that's where I eventually tracked my "chirp" noise to. If that's the source, there's a product you can buy for cheap that fixes it.
Old Jul 19, 2022 | 10:16 AM
Donhim's Avatar
Donhim
9th Gear
Thanks for the inputs. I will try spraying wd40 on the rear hatch. What product are you referring to fox the issue?
Old Jul 19, 2022 | 11:29 AM
IanB2's Avatar
IanB2
Amazon Amazon
Looks simple/cheesy, but completely resolved my noisy latches issue on my wife's '15 GX460.
Old Jul 20, 2022 | 06:08 AM
kgbagent1's Avatar
kgbagent1
Rear door latch, back seat strikers/latch, check tool kit in rear door and wedge foam in there as needed.
Old Jul 21, 2022 | 04:40 PM
John00's Avatar
John00
mine had the right rear loose plastic wheel well. it would make that noise on small bumps AND when going >50mph
Old Jul 23, 2022 | 10:04 AM
Donhim's Avatar
Donhim
9th Gear
I replaced the rear latch today. The sound is still there. Wd40 on all the moving components of the trunk door. Maybe the sound is coming from the front. It’s hard to differentiate since the sound is so low. Checked the rear seats as well. I wd40 the hood latch as well. Hopefully it’s nothing. Don’t want to go to dealer again!
Old Jul 23, 2022 | 11:46 AM
mcomer's Avatar
mcomer
Back to basics, have you emptied Every console, glovebox, door pocket, nook and cranny
of Styrofoam cups, plastic straws, bank receipt folders, children's debris?
Old Jul 23, 2022 | 12:06 PM
Donhim's Avatar
Donhim
9th Gear
I opened and closed all the boxes. My car is pretty empty inside. Mine is equipped with air suspension. Does it have anything to do with it? The car has only 20k miles
Old Jul 23, 2022 | 10:15 PM
camelione's Avatar
camelione
1st Gear
Hi there, I bought a pre-owned 2017 GX460 top spec (full leather, air suspension, 7 seats) from Lexus Dealer with around 70,000km. Since it was new experience for me, jumping from sports car to a body-on-frame 4X4 car I couldn't focus on distinguishing sounds made by the car.
Around 2 weeks later I was driving on a road with kerbs (interlock tiles) I heard chirping sound probably the same one you're referring to.
It happens at low speed and on very small suspension movement such as driving on bumpy road at very low speed -- crawling to be specific.
There doesn't seem to be anything wrong with handling. Took the car offroad on sand dunes but it's all good.
Changed rear shock absorbers 2 months ago since one was leaking, but the sound is still there.
I feel it is coming from the front, maybe bushings?
Old Jul 23, 2022 | 10:45 PM
Donhim's Avatar
Donhim
9th Gear
Yours sounds like my issue. Keep us posted about your findings. Will post an update if I find the cause
Old Jul 24, 2022 | 07:35 AM
Donhim's Avatar
Donhim
9th Gear
Hey, I was moving the second row bench seat forward today and found that it produced the chirping sound. I suspected that that the cause so I kept sliding it back and forth for about 10 seconds. The chirping sound was gone during my 15 mins test drive. Hopefully it’s that easy. The chirping from the second row bench seat movement is exactly the same. Try it to see if it’s the same cause.
ALargeTom
RC F (2015-present)
Nov 24, 2024 02:57 PM
Nooblex
Nov 4, 2021 01:00 PM
Sheriffen
Apr 20, 2017 06:04 AM
situman
Mar 7, 2016 07:22 AM
verylost
Feb 18, 2002 10:46 AM
