Trailer Lighting
Old Oct 29, 2021 | 12:04 PM
MarkVII's Avatar
MarkVII
Default Trailer Lighting
I searched here and could not locate a definitive answer. Am I missing something, connecting to the GX's trailer wiring harness? Whether I connect to the 4-flat or 7-round connectors, I get the same results: tail lights but no stop or turn signals. And to eliminate any trailer wiring issues, I used a test light.
Tail/running lights
Left turn signal
Right turn signal
Helpful owner's manual
Can anyone provide me some insight here???
Old Oct 29, 2021 | 03:01 PM
Acrad's Avatar
Acrad
This trailer circuit is absent from any electronic FSM I have.. I do have a '12 official physical Lexus wiring diagram book that may help shed some light if you find that fuses are all in order in engine by and under dash
I'll try to scan tomorrow but it is like 700 page book so takes some time via flatbed scanning
Old Oct 29, 2021 | 03:36 PM
IanG's Avatar
IanG
Is the 4 plug connection & connector factory? it does not look like mine at all. On mine there is a round multi-connector that plugs into the back of the combination 7 & 4 connector factory trailer connector. If the extension wire shown is an aftermarket item I would be checking it for continuity and checking the factory harness under the back. Could just be a bad aftermarket harness.
Old Oct 29, 2021 | 03:51 PM
Acrad's Avatar
Acrad
Good point... MarkVII: Are you plugging directly into OEM
Looks like extension off of something else
Old Oct 29, 2021 | 04:24 PM
MarkVII's Avatar
MarkVII
Extensions plugged into the OEM connector. Test light used directly into OEM connector with the same results- 12v +, tail lights only.
Old Oct 29, 2021 | 04:31 PM
IanG's Avatar
IanG
This reference identifies a number of fuses labeled "Towing" in both the under dash and under hood fuse boxes.
https://fusecheck.com/lexus/lexus-gx...3-fuse-diagram
Worth a quick check.
Old Oct 29, 2021 | 04:59 PM
MarkVII's Avatar
MarkVII
Thanks!! Both fuses good to go.
Old Oct 29, 2021 | 05:08 PM
MarkVII's Avatar
MarkVII
Direct to OEM connection
Old Oct 29, 2021 | 05:10 PM
IanG's Avatar
IanG
It shows 8 fuses for "Towing"
#4 & #39 Passenger compartment fuse box
#11, #22, #27, #45, #46, #60 Engine compartment fuse box
Best to always eliminate the simple and obvious before more complex diagnosis
Old Oct 29, 2021 | 05:33 PM
MarkVII's Avatar
MarkVII
Guess I read far too fast or it's time for an eye exam
Old Oct 29, 2021 | 05:37 PM
IanG's Avatar
IanG
LOL, I can relate, I'm old and cannot see anything without reading glasses.
Old Oct 29, 2021 | 06:03 PM
MarkVII's Avatar
MarkVII
Now, I can safely say , all eight have been checked good, with a volt/ohm meter. . . thanks again!!
Old Oct 30, 2021 | 01:45 PM
Acrad's Avatar
Acrad
Not sure if you still needed this or not
Old Oct 30, 2021 | 04:52 PM
MarkVII's Avatar
MarkVII
I certainly do. Thanks!! This looks like it's going to be a project.
Old Oct 30, 2021 | 05:24 PM
IanG's Avatar
IanG
This is a long shot but you are using the harness ground for testing the circuits. Just for curiosity sake use the chassis for a ground to test both the light circuits and the ground. Although not is this scenario but I have seen a feedback loop where the ground becomes hot. Just an easy diagnostic step and will help narrow the problem
