DIY #maintenance quick #reference
What grade of gear oil should I use for the differentials and transfer case? I hear 75W-90 from some and 75W-85 from others. What do you use and what brand? Also I think we need something that's GL-5, whatever that means.
If you fall under the normal duty schedule, any fluid upto spec is fine. Usually they'll run about $15/quart.
If you want kits or upgraded fluid
https://www.blauparts.com/parts/lexu...s/ravenol.html
If your current fluid isnt meeting your needs, a great source of information on fluids is an Amsoil Rep that frequents multiple different toyota and oil forums and recommends the following combo:
https://www.tacomaworld.com/threads/...r-oils.639632/
Hope that helps.
