Jack Stand Height For Storage
Old Jul 2, 2020 | 07:43 PM
LexusGXFan's Avatar
LexusGXFan
Default Jack Stand Height For Storage
Last winter I used the Race Ramps Flat Stopper product under my GX and was NOT impressed come spring.
This year, I'm thinking of using jack stands for storage.
Does anyone know what height jack stands I should be looking at to get the tires off the ground ?
Thank you !!
Old Jul 3, 2020 | 07:58 AM
nuclearn8's Avatar
nuclearn8
Thank you !!
I use these:
https://www.amazon.com/gp/product/B074R17GL4/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B074R17GL4/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
what lifting points are you planning to use? the side frame rails front and rear or the rear axle and side rails for the front? I ask because the jack stand above are narrower than the side frame rail to hug them
Old Jul 3, 2020 | 08:08 AM
LexusGXFan's Avatar
LexusGXFan
I haven't thought that far ahead.
What do you use ?
Old Jul 3, 2020 | 04:13 PM
ASE's Avatar
ASE
While this can be argued either way ... if you were to place the jack stands under the frame, the suspension would be fully extended for the duration of storage. My logic is that the suspension was designed to be compressed by the weight of the vehicle when at rest ... so placing the jack stands under the frame would not be my preference.
So if you were to put the jack stands under the rear axle ... just under the spring perch(es) ... the rear suspension would be compressed no different than if the tires were on the ground. To do the same for the front-end would require finding a proper place to engage the jack stands on the lower control arms. I have never done this ... or looked for a suitable location. I am sure there are many opinions out there ...
Old Jul 3, 2020 | 04:43 PM
tecman's Avatar
tecman
I thought this was about ramps compared to jack stands storage, not the GX storage?
Old Jul 3, 2020 | 05:03 PM
ASE's Avatar
ASE
It's about getting away from ramps (contoured or otherwise) and using jack stands to completely unload the tires ... eliminating flat-spotting.
Old Jul 3, 2020 | 05:58 PM
LexusGXFan's Avatar
LexusGXFan
ASE you're correct.
The flat stoppers didn't work as advertised on the GX, even with the special order made specifically for the GX tire size. Still had flat spots, but eventually went away.
I agree with the suspension, but just looking for the best option for a 6 month lay-up !!!
Old Jul 3, 2020 | 08:28 PM
nuclearn8's Avatar
nuclearn8
Could.always Jack up the front using the side frame rails, then pull the wheels off (like you're changing the tires), then use 2 bottle Jack's to compress the front suspension by pushing the LCAs upwards... you'd need 4 Jack stands (2 for rear axle, 2 for front side frame rails) and 2 bottle Jacks (to push the the front LCA upward) for this method.
LexusGXFan
GX - 2nd Gen (2010-2023)
Mar 27, 2020 07:26 PM
6080prado
GX - 1st Gen (2003-2009)
Feb 15, 2016 07:36 AM
BlackCat81
30
Nov 25, 2015 08:28 PM
liner1
Dec 24, 2014 09:56 PM
MSAGRO
Jul 1, 2009 12:18 PM
