Largest tire on 20”
Subscribe
Jan 8, 2020 | 09:43 PM
What’s the biggest tire that you can use on a 20” with a 2” lift with little to no trimming needed to not have any rubbing issues?
Jan 8, 2020 | 10:34 PM
Quote: What’s the biggest tire that you can use on a 20” with a 2” lift with little to no trimming needed to not have any rubbing issues?
What does "big" mean ? ... Width ? ... Diameter ?
Wheel Width = ?
Wheel Offset = ?
Jan 8, 2020 | 11:46 PM
Quote: What does "big" mean ? ... Width ? ... Diameter ?
Wheel Width = ?
Wheel Offset = ?
I guess combination of both?
Jan 9, 2020 | 09:38 AM
Quote: I guess combination of both?
Do you have wheels (rims) ? If so, what is the Width and Offset of the rims ? Without this ... your question on tire size cannot be answered.
Your best bet would to be to go to a tire store and request "the biggest-*** tires on 20" rims" ... so they will be liable for fitment without rubbing.
Jan 9, 2020 | 10:33 AM
You can also use the tire comparison tool/website and get a general idea of what size would be equivalent. Just use the current size as reference and put in 1 or 2 size larger for comparison.
Not many people here run 20" with lift so it would be tough to get a real answer.
Jan 9, 2020 | 12:33 PM
Quote: You can also use the tire comparison tool/website and get a general idea of what size would be equivalent. Just use the current size as reference and put in 1 or 2 size larger for comparison.
... assuming you are using the same rims (width and offset being important variables in tire size determination).
Sorry, but it drives me F'n Crazy when tire size is discussed without reference to wheel Width and Offset ... all are equally important relative to tire interference with the suspension, frame, fender and wheel well !#!#!
Jan 9, 2020 | 02:46 PM
Quote: ... assuming you are using the same rims (width and offset being important variables in tire size determination).
20x9 0 offset
Jan 9, 2020 | 06:43 PM
I hope you like bent rims
Jan 9, 2020 | 11:14 PM
Quote: I hope you like bent rims
why would it get bent?
ive driven 22s and 24s before with low profile tires without bending rims.
i never said I’m taking it rock crawling. If you have nothing valuable to add to the original question pls skip the thread.
Jan 10, 2020 | 04:37 AM
20x9" +0mm offset with 275/55/20 KO2s and a Dob's 2" lift. I'm certain you could go with a 275/60/20 on this setup without needing a BMC. Just plastic trimming and heat gunning.
Subscribe
