Skid plates / Sliders
Old 06-14-19, 12:28 PM
  #151
Acrad
Super Moderator
Acrad's Avatar
Received 3,581 Likes on 2,344 Posts
I threw on my front BB skid today. It co-exists with the factory cover over the AT pan. A small gap but things are still protected. On the oil access panel the front left screw is shorter than the rest. This is because it would contact the front stabilizer bar. Seem to be 5/32 hex
TexasAg (06-15-19)
Old 06-19-19, 07:09 AM
  #152
tigmd99
tigmd99's Avatar
Stupid Q...does the 4runner stock skid plate for fuel tank fit GX?
Old 06-19-19, 06:55 PM
  #153
TexasAg
TexasAg's Avatar
That's what i understand, i just took mine off and plan to install this weekend on 2014 GX. I think i can install the mid and tranny cover with crossbar just need a new front
Old 11-23-19, 06:40 PM
  #154
LexusGXFan
LexusGXFan's Avatar
Default Skid plates / Sliders
I will never take our GXs off road.
when doing maintenance, those two heavy a$$ plates are a royal PITA to remove and replace.
Does anyone make plastic ones or something lighter ?
thank you
Old 11-26-19, 02:54 PM
  #155
Acrad
Super Moderator
Acrad's Avatar
Budbuilt is getting closer to general release. I have prototype skids on mine that cover all the way back over transfer case. I also have a full length BB skid over the gas tank. Access door on the front to change oil filter and drain hole with a Fumoto drain valve on rear. Load bearing & tested oil filter access door.
Post 126
https://www.clublexus.com/forums/gx-...l#post10541501
The following 2 users liked this post by Acrad:
dman3626 (12-07-19), Mistaken (11-26-19)
Old 11-26-19, 02:58 PM
  #156
LexusGXFan
LexusGXFan's Avatar
Thanks. Are they lighter and easier to handle?
i would love something plastic for protection, but nothing else.
Old 11-26-19, 03:03 PM
  #157
Acrad
Super Moderator
Acrad's Avatar
Really no comparison to stock for convenience.
The oil drain just a twist of the valve to drain
https://www.fumotooildrainvalve.com/f103n.html
The oil filter access is just a small panel held in with 5/32 hex screws that one could easily hold in their hand. No removal of any plastics either for the oil filter.
Old 11-26-19, 03:16 PM
  #158
John00
John00's Avatar
i cut a hole in mine and made a cover plate.
Acrad (11-26-19)
Old 11-26-19, 04:09 PM
  #159
LexusGXFan
LexusGXFan's Avatar
Keep us posted when they release these. Thank you
Old 02-01-20, 12:15 PM
  #160
Acrad
Super Moderator
Acrad's Avatar
I am getting a revised prototype mid-skid from Budbuilt.
I'll post pictures when I receive it. One issue I did have with original was oil drain alignment with Fumoto valve wasn't optimal.
If change(s) look good I imagine they will officially go live with general sales.
nuclearn8 (02-05-20), TexasAg (02-06-20)
Old 02-07-20, 05:44 AM
  #161
bigphil001
bigphil001's Avatar
Are you happy with the oil filter access panel on the front skid? I've been waiting for bud built to release the final product so I can order one.
Old 02-07-20, 11:41 AM
  #162
Acrad
Super Moderator
Acrad's Avatar
Definitely happy with it. Oil filter access is trivially easier instead of having to drop that entire front skid.
WRD4chano (02-07-20)
Old 02-07-20, 11:56 AM
  #163
bigphil001
bigphil001's Avatar
As soon as they let me I'm going to order one.
Acrad (02-07-20)
Old 02-19-20, 02:11 PM
  #164
Acrad
Super Moderator
Acrad's Avatar
I got my revised Budbuilt mid skid. Nice load bearing door. I use a Fumoto too.
The oil filter access panel is seen a few posts back
Post 125
https://www.clublexus.com/forums/gx-...l#post10535722
They are also using different gear to retain the crossmember brace. They call them lollipops. :-) I plan to mount this replacement up when I change oil & filter this next weekend.
The following 3 users liked this post by Acrad:
MCDavis (02-20-20), Mojlnir (02-19-20), nuclearn8 (02-21-20)
Old 02-20-20, 05:56 PM
  #165
FLex
FLex's Avatar
Default RCI 15% off sale
FYI:
Facebook Post
The following 2 users liked this post by FLex:
ltsr (02-24-20), msgs350 (02-21-20)
Quick Reply: Skid plates / Sliders
