Interior Color help
Old Oct 3, 2016 | 11:50 AM
airbornm3's Avatar
airbornm3
Default Interior Color help
Hi,
Thank you for your help in advance. The trim around the navigation in my 2013 GX 460 has scratches. I am trying to repaint it to match the rest of the trim but am having difficulty matching this color.
My color codes:
C/TR: 077/LA40
A/TM: A01A/A760F
I am attaching the picture of the color which is similar to champagne/goldish silver? Can anyone help with how to match this paint or have a color code? Thanks
Old Oct 3, 2016 | 01:56 PM
tecman's Avatar
tecman
Let me know if you find something and I will be the test subject. I did this sliding a ladder in and out of the rear. It's in an inconspicuous area and stays covered up anyway. Your dash is right in your face and needs to be perfect. Probably needs to be professionally matched and sprayed with a quality paint gun.
It would have been nice if Lexus had put the silver in the plastic, but black plastic?
Old Oct 4, 2016 | 06:38 AM
airbornm3's Avatar
airbornm3
I have been playing around with an airbrush and modeling paint. I went to an automotive paint supplier and they were unable to match it. Also, I spoke with Lexus and they do not have a code for the trim paint, makes no sense to me since this is used on other models as well. So far, I am coming very closing mixing the following model paint colors together:
Testors
German Silver Metallic - Gloss -
271407
Flake Gold - Metallic -1542TT
Old Oct 4, 2016 | 06:41 AM
airbornm3's Avatar
airbornm3
I think it is a worthwhile pursuit to get a code or a close match to this color because the paint they use is very fragile and the color is used on many models. Does anyone here work at a paint shop or have a spectrophotometer? Thanks
Old Oct 7, 2016 | 08:01 AM
airbornm3's Avatar
airbornm3
Ok,
Yesterday I painted the rear AC control panel and have come very very close in color, it's only discernible under bright lighting. I bought Duplicolor paint, see attached, and sprayed it in a small cup then I airbrushed the paint on. Clear coat applied afterwards. It looks like new. I'm sure if you were to paint 2 pieces that are butted up against each other you would be able to see a small difference and would have to blend the paint or paint both pieces. However if you painted just your door handle it is far away from another trim piece of similar color and you would not be able to see a difference. Good Luck!
Old Oct 7, 2016 | 03:20 PM
tecman's Avatar
tecman
I will play, I don't have an airbrush and I'm intrigued.
Old Dec 7, 2016 | 12:24 PM
kroorda's Avatar
kroorda
I'm also interested in getting some of these custom colors; for both interior (dash/trim) and scratches on the wheels and even the grill. There are a number of 'touchup paint suppliers' on the internet who say they can supply paint for all these areas. However, it's easier said than done. Going the 'Duplicolor' route seems to be the most reasonable thing to do as they make colors that are very close to the oem colors.
Old Dec 7, 2016 | 05:13 PM
Smilesb's Avatar
Smilesb
Hello,
New to the forum.... Do you have any "after" pics of using the dupli color? I am also wanking to touch up my drivers side interior door handle. Previous owner scratched it up pretty good.
Thank you!
Old Dec 7, 2016 | 06:17 PM
tecman's Avatar
tecman
DupliColor
Too much gold
Sprayed this on a blank wall plate.
Preped and ready to be painted. I played with the air brush and got sidetracked.
Old Dec 7, 2016 | 06:45 PM
Smilesb's Avatar
Smilesb
Thank you!!! The Dupli Color looks great!!!!
Old Jul 27, 2017 | 04:38 PM
Acrad's Avatar
Acrad
Do you have a picture of how it looks now? Made a small mark on rear door handle I might try to fix.
Thanks!
Originally Posted by tecman
DupliColor
Too much gold
Old Jul 27, 2017 | 05:27 PM
tecman's Avatar
tecman
Never got around to it. This is where my panel is now. The air brush that I bought is frustrating and I put it away for now.
Old Jul 27, 2017 | 06:12 PM
Acrad's Avatar
Acrad
Mine is just a small single ball point looking dot... have to wonder if I shouldn't just try some kind of silver colored pen. It won't make it go away but might be less noticeable than the standlaone black dot that is there now.
Old Jul 27, 2017 | 09:13 PM
User21c's Avatar
User21c
I tried this on some small 'nicks' on my lower center console... same color as discussed above.
It helped if you just do very small 'dots', and rub it out/smooth after it dries for a day...
https://www.amazon.com/gp/product/B000ALDZ0G/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000ALDZ0G/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Old Jul 27, 2017 | 09:30 PM
caesosa's Avatar
caesosa
Cool. I will give it a try in the rear door panel that gets kicked by the baby.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
