#Vibration / #Shake Issues
Old Oct 21, 2020 | 08:13 AM
  #751
Options2k's Avatar
Options2k
Originally Posted by WRD4chano
about the brakes, what is better about it? sharper pedal, more bite?
Brake travel is reduced and more bite. My 2006 GX brakes were like a car but the 2019 had much more travel. The new one is back to feeling like my 2006....except of course, the slight vibration.
Thank you on the suggestion of greasing the zerks....I have passed this along to the shop. I will check what tires once I get it back.
Anything else to check?
Old Oct 21, 2020 | 08:16 AM
  #752
Options2k's Avatar
Options2k
One more question. Does the suspension setting play a role in vibration? I have it set for comfort, similar to my 2019, as this is my wife's daily driver.
Thank you!
Old Oct 21, 2020 | 08:47 AM
  #753
LexusGXFan's Avatar
LexusGXFan
One simple check....Have you checked tire pressures?
Old Nov 1, 2020 | 01:43 PM
  #754
Options2k's Avatar
Options2k
Update: I picked up the truck yesterday after 12 days at the dealership. I am happy to report that the vibration that I felt between 40 - 70 mph speed is gone and it felt like I was driving a “normal’ GX back from the dealership. I believe they road force balanced the tires, twice, did 4 wheel alignment and fixed something in the steering rack related to pre-load. However, based on the report, there was still some “flutter” (this is what they called the vibration) at around 60 mph so called the services of the regional Lexus tech specialist to check my truck. He advised them to do a second alignment with a bit more toe-in. That appeared to have fixed it! The service manager, as I had elevated the case, test drove with me to make sure that it was to my satisfaction. He told me that this is the first time they had to do something like that and made a note if some other GXs come back complaining of vibration/flutter. I am a happy Lexus customer, once again!
some were wondering what tires came with the truck? Dunlop.
cheers🍺
Old Nov 1, 2020 | 03:29 PM
  #755
Acrad's Avatar
Acrad
That is interesting they may have replaced a pre-load spring in the steering rack. There was a TSB back in spring of 2012 that addressed this. This TSB occurred after the build date of my GX (02/2012) but have never experience it myself.
https://www.clublexus.com/forums/att...sb-0020-12.pdf
Old Nov 2, 2020 | 04:47 PM
  #756
Beastman's Avatar
Beastman
Default Slight vibration under light load
On hwy I give gas going up a very slight incline and I can feel a vibration that isn't constant but cycles ever couple seconds or so from normal to vibration. I have 97,000 miles. Thanks in advance,
Bill
Old Nov 2, 2020 | 07:56 PM
  #757
WRD4chano's Avatar
WRD4chano
from past posters with similar experience, its the tires. are you using bridgestones or michelin defender?
Old Apr 8, 2021 | 01:32 PM
  #758
xdwang's Avatar
xdwang
Default 2021 GX460 feel shake at 65m/hr speed
Hi Everyone, I got my 21GX and run for ~1000 miles. I found the truck 'shake' (my leg feels the vibration when lean on the door panel) at 65 miles/hour. I went to the dealership and they balanced the four tires and also I went test drive with a technician in another 21GX to compare with. Same fell, vibrate at that speed. Their explanation is the truck is high and that vibration is from the resonance of wind, engine, and truck structure. Does anyone have the same feel driving the truck? Appreciate your thoughts.
Old Apr 8, 2021 | 07:01 PM
  #759
xdwang's Avatar
xdwang
Originally Posted by allcruise
1,200 miles on my gx 460. dealer states, he has balanced all tires, and checked for radial run, at 60-65 miles, my steering wheel shakes.
They said they need to escalate this to a task case for lexus regional manager.
what would you fellow owner do???
Hi Allcruise, did you solved the problem? I have a new 21GX, exactly same steering wheel shake issue. The dealer balanced the tires and I test drive another 21GX with a technician. Same thing happen to that test drive truck also.
Old Apr 9, 2021 | 04:35 AM
  #760
M4rk's Avatar
M4rk
Welcome aboard. I don't recall anything like this in my '21, but then again 65mph or 105km/h isn't a speed I commonly drive at. I will test it out soon. At what speed does the vibration dissipate?
Perhaps adjusting tire pressures could also help. I find it hard to believe Lexus would something like this slip. Not to trash Subaru, but this would be a Subaru thing (as I experienced).
Old Apr 9, 2021 | 08:13 AM
  #761
ASE's Avatar
ASE
That is a ridiculous explanation. At speed, look at the rear view mirror and look at the unoccupied passenger seat headrest ... if either are vibrating, that indicates tire imbalance. If this is found to be the case, take to a dedicated tire store that has the equipment to "Road Force" balance your wheels. They will also be able to tell you (unbiased) if your tires are out-of-round or require anexorbitant amount of weight to balance.
Old Apr 10, 2021 | 01:56 AM
  #762
jkonquer's Avatar
jkonquer
I don't have problem with my 21 and didn't have problem with 18 either.
Old Apr 10, 2021 | 02:40 PM
  #763
corpnupe85's Avatar
corpnupe85
I have the same issue in 21 GX 460 with the 19 inch wheels. After 1,000 miles, the vibration is less. I told them to perform a 'road force balance' and they would not. I can, but should not tolerate any VIBRATION at all. I am thinking about getting another vehicle anyway.
Old Apr 12, 2021 | 07:35 AM
  #764
WRooster's Avatar
WRooster
Sounds like a wheel weight was possibly thrown off. I would check there first.
Old Apr 13, 2021 | 04:41 AM
  #765
lovemyGSFS's Avatar
lovemyGSFS
That could be the tires I had the same issue on my ES I know these are totally different vehicles or the truck is just totally unbalanced if you said it's happening on another 21GX
