Front wheel wells rubberized cover
I've noticed there is quite a difference in what a rubberized compound covers inside a wheel well for driver vs passenger side.
Here is the passenger side:
You can see the rubberized compound covers the whole top of the wheel well.
Here is the driver side:
This looks like a half-*** job. Also is there a bolt missing in the middle? My concern is that compound is supposed to protect from rust caused by the stone chips. How it looks on yours?
Thanks, also if you could check whether that bolt hole I have in the middle is empty on yours as well or used to hook some gear for the premium version that would be great!
I'm thinking about at least covering that hole with some 3M outdoor tape... From my experience with owning other cars during winter salt and road debris get into the holes inside wheel wells and then start to rust and corrode stuff inside the engine bay. Need to check whether that hole indeed ends up in the engine bay first though. Did you figure out what the material not covered by the insulation is made of? Trying to figure how rust prone it is.
So I popped up the hood and the hole is going directly into the engine bay. I'm gonna plug it with some 3M tape.
The undercoat is probably done by robots. They wouldn't "half-***" the spray, it was programmed that way.
Looks like it's deliberately uncoated, and with the unfilled hole right there I would think it was for installation of a part or option for a different market.
I'm going to plug the hole with a dab of clear silicone.
