Caster alignment input
Hello,
this past Friday I had my gx leveled with the bilstiens and now my front right tire rubs the side steps. I was debating on just cutting off the inner portion of the step but I don’t know if I really want to cut into it. The current caster is set at 3.6 Driver and 3.3 Pass. From my research a lifted gx should be between 2.5 and 4.1. Being that the current alignment is basically in the middle of the recommended range. What’s peoples opinion on adjusting it to where it no longer rubs or just cut off the side step rear. I’d probably have to cut off about 1.5” from the bottom rear of the steps.
thanks in advance.
thanks in advance.
aftermarket ucas with built in caster do get the wheel closer to body mount.
Thinking out loud here: what I don’t know is if all these alignment machines account for aftermarket caster or if they assume the ball joints are in their OE locations.
Unless they take time to measure the NEW ball joint locations and their respective angle to get the steering angle (or whatever the outcome is called), the machine might not really know and in theory you might have more caster than the printout says.
that’s all to say, maybe dial some OUT and the wheels will get further from the rear body mount and running boards while still performing fine.
... it's the -12mm Offset ... stock +25mm to -12mm places a stock sized tire 37mm (1.5 inches) in the outboard direction ... with an approximate 2:1 loss in clearance to the front body mount. No way Caster can compensate ... maybe 0.5 inches of (move forward) additional clearance.
Have 265/70-17 Nitto A/T's on 8.5/17 wheels with +1 Offset ... dead-nuts centered in wheel well and am JUST on the hairy edge of rubbing with a fender liner pull-back both fore and aft.
They gave us the info.
Was stock with the wheels/tires - no spacers. Of course -12 is aggressive, but it did not rub stock, so moot point IMO.
Added 5100s and UCAs only.
No surmising was done.
OP, I too would have caster adjusted to move wheels forward - see if you get it good.
^ ... Ready, Shoot, Aim ... no parameters were in original post other than "Bilsteins" and "Lift" and "UCA". And yes ... -12mm Offset is way too aggressive for the GX without significant challenge.
