Tire Warning light on dash
Old Sep 20, 2025 | 10:59 PM
Framestead's Avatar
Framestead
If you havent periodically lowered the spare tire, try. Penetrating lube the mechanism, wd40 to flush, and then apply your favorite rust protector like fluid film or surface shield. Thing will move like butta. That being said, i assume tire carriers need replacement since ebay is full of them being sold used.
Lexus does say to do a 5 sided tire rotation for the GX, but getting a shop or dealer to follow that recommendation isnt automatic or implied.
Old Sep 21, 2025 | 04:05 AM
AmosHarrison's Avatar
AmosHarrison
Yes, you always have to specify a 5 tire rotation or they'll go with 4. The price is the same.
Old Sep 21, 2025 | 09:14 AM
John00's Avatar
John00
a squirt of lube while youre doing the oil change can prevent any issues.
Old Sep 21, 2025 | 12:48 PM
Framestead's Avatar
Framestead
I would run 50 psi cold, but have heard that might set off the tpms (any extreme psi low or high). I have heard, folks who tracked their 2nd gens to and from port, reporting higher then max, but i guess tpms was in transport mode.
Old Sep 21, 2025 | 03:34 PM
ASE's Avatar
ASE
... on my FJ Cruiser ... running LTX-E tires at 55-psi ... TPMS does not care. Also on GX460 ... running LTX-E tires at 46-psi ... TPMS does not care. Run 60-psi on both for spare tire ... TPMS does not care.
Old Sep 23, 2025 | 08:47 AM
craigrpete's Avatar
craigrpete
I agree it’s probably best to lower the spare fill it with air and lube the hoist mechanism periodically.
Having said that, it’s not fast or easy. I have the hardest time centering the tire when lifting it back up into the well.
I’ve added an extension to the valve stem that mounts on the trailer hitch so I can check tire pressure much more easily throughout the year. Roughly once a year I lower it to lube the hoist.
OP also if you’ve never changed your TPMS sensors yet you’re about due. You can bring your own in to Costco and they’ll mount them for you for like $10 each.
Old Sep 23, 2025 | 12:09 PM
CaroneK's Avatar
CaroneK
Thanks for the Costco tip. My GX is a 2011, so I would expect the batteries to fail fairly soon.
Is there a “go to” site for buying the TPMS replacements? I just bought a new set of winter GX floor mats on sale with free shipping from Prestige Lexus in New Jersey. I think that annual Lexus sale may have ended however.
Are aftermarket sensors available and advisable?
Thanks.
Old Sep 23, 2025 | 02:21 PM
ASE's Avatar
ASE
^ ... beware ... many shops will not install customer supplied parts unless they are specialty ... they don't wnt to be responsible for something not working that is parts related. In the inverse, I would think one would want to hold the shop accountable for the end result ... comprised of Parts and Labor. Yes, the shops would like to have the parts markup ... but this approach does protect all parties. Also, while some shops will install customer provided parts, many then offset loss of parts markup on the Labor side of the quote.
Also, unless Amazon is an Authorized Distributor ... there is absolutely no warranty coverage provided by the Manufacturer or Amazon ...
Old Sep 29, 2025 | 09:11 AM
craigrpete's Avatar
craigrpete
Originally Posted by CaroneK
Hi -
The “tire warning” light has come on recently. The tires are less than 2 years old (not sure that matters) and I checked the tire pressure and all are spot on. A TPMS sensor? If so, is there a way to determine which wheel may have an issue? How to resolve? Do I buy a sensor and next time I rotate have them replace it. Could it be something else?
2011 GX
Thanks in advance 👍🏼
its probably a battery on one or more of the TPMS sensors has gone out. But just to double check, did you check the pressure in the spare it has a sensor too?
On my ‘12 i just recently bought 5 OEM sensors off of ebay and had costco install them for like $10 each. I wouldn't wait till you replace the tires it wont save you anything. Costco can diagnose which sensor has gone bad and just replace one, i just didnt want to fix one by one since the batteries on all of them were getting old.
Old Sep 29, 2025 | 09:49 AM
lexo98's Avatar
lexo98
Costco’s policy is only to install their own sensors. You got lucky
anewbie1
RX - 3rd Gen (2010-2015)
30
Oct 6, 2025 08:53 AM
Needabreak
Mar 28, 2025 01:19 PM
mixpat
Aug 9, 2022 04:01 AM
Allusuc
Feb 14, 2022 02:06 PM
gebo
GX - 1st Gen (2003-2009)
Sep 23, 2018 05:56 AM
