Squeal sound at low speeds
When I first start driving up to ~35 mph I get a squeal that sounds very similar to the squeal you hear when you have older brakes that need replacement. It is not very loud but It is definitely coming from the rear. It is not consistent/doesn't happen after I have been driving for a while.
Does anyone have any thoughts or had something similar happen?
I had a similar issue recently from the driver's side rear wheel. Turned out to be that the brake pads were not installed properly with missing hardware. Not sure how that created the squealing sound as they were working fine for the past 20k miles, but maybe they became misaligned and started dragging on the rotor? Had them re-installed with the appropriate shims and clips and the noise went away. I ended up replacing the rotors and pads when I got back home (I was on a road trip at the time), using GX460Bob's detailed video as a guide and have not had any further issues since.
The calipers are known to be somewhat (internal) corrosion sensitive ... to the piston sticking comment above ... so best to flush the Brake Fluid every 3-years to purge moisture and keep the system clean ... or use test strips to stay just ahead ...
Reedearl
Jun 25, 2009 01:13 PM
1994 LS400
Jan 2, 2002 05:41 PM
